Carbureted LSX forum - tach on a 6010 problems
View Full Version : tach on a 6010 problems
Hantzum
08-12-2012, 06:03 PM
Okay, my 6010 box is working great but my tach is way way off. When its idling the pro-data software has the Rpms about 800-900 ish which sounds right. I know what 800-900 rpms sound like. but my auto meter tach is showing 1500-1800. So I thought well its just off at idle. Well I take it to the track and its about 5000 rpms off. The SOB maxed out at 10000 rpms when I was probably at 6000 or so and my shift light also went of way early too. I have my shift light and tach butted together off the yellow tach wire off the box. Anyone know what I can do to get the tach to read correctly? Ohhh and before you ask this tach worked great on the stock pcm. Was dead on so I know the tach is okay.
ZONES89RS
08-12-2012, 08:42 PM
Ok, we talking went from EFI to carb? Lot of guys set the tach to 4 cylinder Mode with the 8 coil setup to make it correct and if so you have a tach thinking it is running a 4 or 6 cylinder and putting out allot more with the single output from the box registering 8 cylinders. See if there is a selector on the back of th tach or of it is the cheap one it will have wires that are cut for the same purpose.
streetknight2
08-12-2012, 10:53 PM
Mine acts goofy too, it idles around 1000, but sometimes the tach will show 500. Gonna start chasing that gremlin this week
Hantzum
08-12-2012, 11:42 PM
Ill check that out....yes I went from EFI to carb to answer your question. I dont think this tach has that setting for a 4 cylinder input... I know what you are talking about because these POS stock pcm dont read correctly unless its set to a 4 cylinder input....Ill check it out on the back of the tach and let you know...It is a sprot comp 1 auto meter tach too for reference....
wildcamaro
08-14-2012, 03:05 PM
I'm curious to see what fixes ur issue bc I'm trying to run stock 81 camaro tach off the msd yellow wire...I know you could probably experiment with different resistors inline with your tach feed but that could be time consuming...try the tach with the shift light wire out of the picture...it's worth a shot
LS1MCSS
08-18-2012, 02:41 PM
There will be a brown and orange wire looped out of the back of the tach. Most likely they have been cut, for a 4 cylinder signal. If so, you have to solder them back together.
