New Tensioner Pulley & Cap from MBA @ Thunder Racing
MBA now offers a tensioner replacement pulley & cap for your 1998-2002 F-Body. This part includes a replacement pulley assembly with a NEW sealed roller bearing, Machined Aluminum Cap and installation hardware. Available in Black, Red, Blue, Satin or Polished Finish.
http://www.thunderracing.com/catalog...d=444&pcid=195
As usual, these are beautiful MBA quality.
Angie
Angie
Angie,
Is it exactly the same diameter as the stock pully, because I replaced my radiator hose with a flexible chrome hose and it comes about .25" from the hose. Just want to make sure it clears.
Thanks
Thanks
This should just be the pulley, not the tensioner (i.e. katech or stock tensioner).
Remove the bolt on the stock pulley your using and bolt this in its place !
I would also expect that it be the exact same diameter... We'll see soon, I put my order in this morning.
Our tensioner is the same diameter as the stock plastic piece and is designed to just replace the plastic pulley. The Cap does add about 3/8 or so of an inch toward the front of the car.
It is designed to mount tt the stock spring tensioner. Fitment on other aftermarket tensioners assemblys was not checked.
Hope this helps.
Paul Roswell
Sales Manager@ MBA
Hope this helps.
Paul Roswell
Sales Manager@ MBA
is it a solid tensioner, it looks self adjusting, like stock, which a lot of people with more horsepower have issues with the belt coming off, now maybe if there is a bigger lip on the pulley that issue can be resolved.
nickn20,
Our pulley just replaces the stock plastic pulley, The actual tensioner is the
stock piece on your car and you reuse it. We are not selling a whole replcement tensioner. But, yes we did make the outer edges a little taller and thicker than the stock plastic pulley.
Hope this helps.
Hope this helps.
