LS4 Performance - Won't start
View Full Version : Won't start
blkchevyz
08-12-2012, 10:08 PM
I'm finishing up my transmission swap and just got to the point where to start it up. Put the key and the display starts saying to service abs, brakes, stability... When I try to start nothing. So I figure it's related. Anyway I think I got everything hooked up, wheel sensors and the few transmissions sensors. Any ideas?
91parkave
08-13-2012, 03:23 AM
go back and check the PRNDL switch you probably didnt seat the connector it happended to me when i replaced my trans also check your started and make sure all your wires are going were there supposed to and tightned
blkchevyz
08-13-2012, 09:58 AM
That's the big connector on the top correct? That seems good, I'm taking the starter to get tested to make sure it didn't get beat around
gxp-miller-gxp
08-13-2012, 11:33 AM
Also check and make sure everything is grounded nice and good , had similar problems when I had a ground for the tranny comes loose
blkchevyz
08-13-2012, 11:44 AM
Everything seems good I got 4 grounds going to the trans. What would I look for If my computer is shot? Had it retuned for the transmission as well
blkchevyz
08-13-2012, 12:06 PM
With the car off should it know what gear it's in. If I shift it it's still saying its in park
blkchevyz
08-13-2012, 05:18 PM
Well ended up being a broken ground on the passenger side, must of broke when I jacked up the motor
gxp-miller-gxp
08-14-2012, 10:45 AM
Glad u you figured it out , let us know how it rides
blkchevyz
08-14-2012, 02:37 PM
feels like a new car. i can really tell my rpms dropped when cruising around, so its got a lot less slip in it... before it felt like i was driving around with a huge stall.
