Street Racing & Kill Stories - 240sx LS1 Swap Heads and Cam 422 HP / 2001 C5 ZO6 370 LQ9 13.7:1 CR 485 HP
04BlackGmc
08-12-2012, 10:36 PM
Both cars tuned by me.
1991 240SX Hatch
LS1
T-56
Magic Stick 3 (MS3) 237/242 .603"/.609" 113 LSA
Ported 853 Heads
Full Exhaust
Ls6 intake manifold
2001 C5 ZO6
370 LQ9
13.7:1 CR
Race Gas
244/248 .612/.615 112+1
Stock L92 heads milled
Stock Ls3 intake
Full exhaust
Vararam
The vette made the 485 on 31.5* of timing now it has 33* in it.
http://www.youtube.com/watch?v=rNxVZ8igwcg
Tracked350Z
08-12-2012, 11:52 PM
When it comes to this kind of build I am very uneducated. But as for the Z06, is the LS6 not the better engine to do that ridiculous of a build? Monstrous cam, high compression, and race gas. Please correct me if I am wrong. Also isn't that LS3 intake holding him back as well?
04BlackGmc
08-13-2012, 12:15 AM
He blew the last motor on bottleso he went with a 6.0 block build. Car will be sprayed soon. Yea stock ls3 intake and unported l92 heads (they are only milled)are holding him back a good amount, i bet he could pick up 50 or so with some porting to the heads and a fast 102.
07 z71 silverado
08-13-2012, 04:05 AM
why so much compression lol. I put down 506 rwhp at 22* of timing 12.4 AFR with 11.2cr with my TFS 225cc Heads on pump gas on my ls2. Just seems a little extreme to me. SICK but a little extreme.
6PntHo
08-13-2012, 06:06 AM
Two sick cars. Nice runs.
04BlackGmc
08-13-2012, 10:00 AM
i hear ya man he said it was a budget build thats why no fast or ported heads or anything(but runs race gas only lol) a set of heads would wake this car up
ajrothm
08-13-2012, 11:49 AM
Pretty disappointed in the Z06.... The 240 though is a good little runner for what it has...
A near 14-1 comp, race gas 370" and 244/248 cam with LS3 top end only making 485?? Something isnt right there... Even if thats the case, thats still 60hp more then the 240 makes and they can't be that different in weight... Looks like they run about even or maybe an edge to the 240...
04BlackGmc
08-13-2012, 11:55 AM
A near 14-1 comp, race gas 370" and 244/248 cam with LS3 top end only making 485?? Something isnt right there... Even if thats the case, thats still 60hp more then the 240 makes and they can't be that different in weight... Looks like they run about even or maybe an edge to the 240...240sx weight is 2760 without driver im sure the vette is around the 3100-3200 area he hasn't weighed it, now it does have a iron block which adds 70lbs but has no ac.
I had the car on the dyno with the street tune 12.6-12.9 AFR it made right at 480 i added a degree and made 485 had 31.5 at the time and left it at that. Now since then i did add another 1.5* of timing but havent hit the dyno i honestly think and told him there is a few things holding the car back. I bet with a GOOD set of heads and a more friendly 93 octane CR and a fast 102 it would do close to the same numbers it does now.:cool: Gotta realize they are unported untouched l92 heads besides the milling and a cam choice more towards that would help.
Thanks on the 240 the car was def fun to build and i think is setup very nice. I'm wanting to soon do a fast 92/92 and a UDP and maybe crack the 450+ mark on a dynojet.
ajrothm
08-13-2012, 12:10 PM
Damn I didnt realize the 240 was that light..... 400lbs difference will definitely eat up a 60-75hp advantage for sure....
Yes I just read the LS3 heads are stock...That has to be the bottle neck.. Although with what they flow stock, I still think it should have made a little more but..... Sometimes (most times actually), they never do what we "think" they should do.... That has always been my case...
Atleast he has a good foundation and can slap a top end on it and pick up 50-60hp probably.
04BlackGmc
08-13-2012, 12:17 PM
I agree with you problem is alot of people think the l92 heads do great now they are a decent head but in a combo like this they are the issue i think.
Yea it doesn't take anything crazy to get a light car to move out well. This is a fun platform for sure with a ls.
raymond mckinney
08-13-2012, 12:33 PM
I think with the extra weight the vette ran ok. I would do a fast and some head porting though to make the most of the combo.
