just finish cam install what oil should i use
Old 08-12-2012, 10:45 PM
spiro27's Avatar
Default just finish cam install what oil should i use
just finished my head and cam install. what oil should i use to break in the cam. should i be running any additives they have for breaking in the cam. it is a eps cam made by comp cams. thanks for help. when can i run synthetic oil again.
Old 08-12-2012, 10:53 PM
JS01's Avatar
It's a hyd roller, doesn't need to be broken in, use the oil you normally run.
Old 08-13-2012, 05:57 PM
spiro27's Avatar
can i put in sysnthetic oil again with cam.
Old 08-13-2012, 05:59 PM
spiro27's Avatar
can i run synthetic oil and synthetic oil stabilizer
Old 08-13-2012, 06:01 PM
Darkman's Avatar
I would skip the stabilizer - it increases the viscosity and delays lubrication on cold starts, which is when most wear occurs.
Old 08-13-2012, 06:14 PM
sweet99ss's Avatar
Like said above use the same oil you normally use. You should always try to run the same oil that you put in it before. Find a brand of oil you want to use and stick to it. Mixing oils is not good.
Old 08-13-2012, 06:25 PM
spiro27's Avatar
its had mobil 1 oil in it foreverer gess i put it back in.
Old 08-13-2012, 10:19 PM
garygnu's Avatar
would some of the gibbs brake in oil help ?
Old 08-14-2012, 02:22 AM
Blk98Vert's Avatar
No, you dont need to break in a hydraulic roller. Period
Old 08-14-2012, 05:13 AM
baxsom's Avatar
only flat tappet lifters that had flat metal running on the cam lobe need special break in oil. Roller lifters are gtg with whatever oil you always use.
