Rob94hawk
08-13-2012, 01:18 AM
Is it possible for the elastomer in the balancer to be worn out enough that the vibrations are no longer being absorbed and can lead to the pcm pulling timing back? Or on a stroker engine the balancer just not absorbing enough vibrations throughout the rpm range that it would pull out timing? Thanx
S10xGN
08-13-2012, 09:04 PM
Physically, no. Electronically... ?
Wnts2Go10O
08-13-2012, 09:55 PM
if the engine goes out of balance because of the disintegration of the polymer.. the knock sensors ..may.. pick it up as knock.. maybe..
joecar
08-22-2012, 08:59 PM
Why would the PCM pull timing (how would undamped crank oscillations be picked up by the PCM)...?
