Carbureted LSX forum - King Demon RS for 408
View Full Version : King Demon RS for 408
onefast84
08-13-2012, 10:24 AM
I am planning on putting together a 408 for my camaro. I picked up a king demon rs 895 for a great deal!! I will be running a custom grind cam(tbd later), gmpp intake, patriot stage 3 243's, msd 6010, and 1 3/4 long tube headers!! Is This going to be a good carb for my build, or should I stick to a standard 4150 style. I will be adding nitrous too. However the chassis will need to be upgraded to go 9's!! Thanks!!
daniel044
08-13-2012, 11:25 AM
Should be fine with that carb, I have a Pro Systems 1000 on mine and its almost dead on when I bolted it down. Should be a aggressive setup pending the cam selection.
A suggestion of mine is to run 1 7/8" headers, they will just flow better and give more HP.
If you use nitrous I would get a small tank and do it stand alone.
Are you going high compression? and what kind of car is this going in?
3pedals
08-13-2012, 02:23 PM
The 4500 style carb will only be happy with a 4500 style intake. Adaptors are not the solution either. If you dont use a 4500 style intake, then don't use the 4500 carb
onefast84
08-14-2012, 09:22 AM
I think I am going around 12:1 comp. I also have the parts to convert it to a 1050 also! I have seen this carb run and it was working great with the adapter, so hopefully it works fine for me. I do plan on using a 4500 intake later on though. Thanks!!
