FastFitters35th
08-13-2012, 02:16 PM
Glad to be a part of the LS1 family! Loving my, recently purchased, '02 35th anniversary SS. Here is a list of mods done prior to me receiving it:
AFR 205 Cylinder Heads
228 / 228 dumLSA 14 camshaft
Mellings Hi-Perf Oil Pump
Rollmaster Double Row Billet Timing Set
Ford Racing SVO 42 lb Fuel Injectors
SLP CAI Lid & Intake
JetHot Long Tube Headers
True Dual Exhaust - "X" Crossover with Magnaflow Bullets
SLP Dual CME Outlet
Precision Industries Multi-Disc 4400 Stall Converter
TCI SFI Flex Plate
Trans-Go Shift Kit
B&M Transmission Cooler w/7 duminch Fan
SLP Roll-Stop Brake Lock
Power Slot Rotors w/Hawk Pads
UMI Chrome Moly Shock Tower Brace
Front Global West Adj Coil-Over w/Koni Sing Adj Shocks & Eibach 55o lb Springs
Rear Koni Sing Adj Shocks & Eibach 180 lb Springs
Hotchkis dum1.4375 dia Front Sway Bar
Hotchkis 1.0 dia Rear Sway Bar
UMI Upper Adj "A" Arms w/spherical rod ends & moog ball joints
UMI Lower Adj dum"A" Arms w/spherical rod ends & moog ball joints
UMI Chrome Moly Dbl Adj Rear Control Arms w/spherical rod ends
UMI Front Tubular "K" member
UMI Control Arm Relocation Brkts
BMR Panhard Relocation Bracket
UMI Chrome Moly Dbl Adj Panhard Bar w/spherical rod ends
UMI Tunnel Brace Mounted Adj Torque Arm
Global West Welded Sub-Frame Connectors
Custom Tuned by Rick Hollenback / Synergy Motorsports
I've done a little personal preference mods to it but nothing more noticeable than the headlights and taillights. Have many plans for this car though!
SLP Dual CME Outlet
TCI SFI Flex Plate
Trans-Go Shift Kit
