HELP Cam install snag with pictures
I have just about everything off for the cam install but ran into a few things in the process.
1. Is it normal for there to be this much oil under the valve covers? It is pooled up somewhat in the rear corner because the front end is off the ground
2. Is it normal for this amount of what looks like corrosion on a 6 month old water pump?
3. I see what looks like a chip on my head you can see here in the picture is this something to worry about? This is loacted just below a rocker bolt hole, and is a similar one on the other head just below another rocker bolt hole.
4. Also wondering if I should not have used thread sealer on my rocker bolts and ARP head bolts last time I had the heads off? Because now it seems some of thread sealer has hardened and after removing the rockers there is some thread sealer that has hardened into a sort of gasket in between the aluminum head material and the rocker washer you can see in the pic below. What are most using on rocker bolts and head bolts?
Thanks
Thanks
