Meen95z
08-13-2012, 10:09 PM
I have qa1 single adjustables on my 95' Trans Am, and they sit on a angle. They are bolted in factory locations. Would the brackets that relocate the shock bottoms to line the shock up even benefit me? I mean it makes sense the shock is in a bind now, so they would help. Just wanna make sure before I weld a set in. I dont care about the knob placement, its a matter or does it help the suspension work better?
Detroitmuscle
08-14-2012, 08:46 AM
the intention of those brackets is to prevent bind and I would say that it will only help.
223HAWK
08-14-2012, 12:00 PM
We made a set for my shocks...really easy. I'll post pixs later
BlackDuk98
08-14-2012, 01:58 PM
Definitely worth adding them. You can pull them from mustangs at a junk yard for a few bucks. Need to redrill the holes on the rear end to the appropriate size and a minimal amount of hand filing to the shock. Work great for dirt cheap and you don't have to weld them if you don't want to.
