Dynamometer Results & Comparisons - tsp 408 build complete with pics and numbers!!!
backdraft408
08-13-2012, 11:51 PM
http://ls1tech.com/forums/picture.php?albumid=25941&pictureid=92036
http://ls1tech.com/forums/picture.php?albumid=25941&pictureid=92033
http://ls1tech.com/forums/picture.php?albumid=25941&pictureid=92032
http://ls1tech.com/forums/picture.php?albumid=25941&pictureid=92029
http://ls1tech.com/forums/picture.php?albumid=25941&pictureid=92027
http://ls1tech.com/forums/picture.php?albumid=25941&pictureid=92026
http://ls1tech.com/forums/picture.php?albumid=25941&pictureid=92025
dyno was on a Mustang 1100SE dynamometer. I stated i was looking for 550rwhp and 500rwtq. i was informed that those number on the mustang would be around 470-480rwhp. after a few days of dyno tuning and work numbers were 462rwhp and 442rwtq. numbers were very close to what i was going for. the car has crazy torque and insane acceleration. meth kicks in at around 6 grand. car idles great and is very smooth. the stroker is even smoother than my stock ls1. very happy with the way the car drives and responds.
wildcamaro
08-14-2012, 12:16 AM
What are the specs on the motor? I thought number would be closer to 500...
backdraft408
08-14-2012, 12:25 AM
number are over 500 its just the mustang dyno it was on. i know it has way more power then my old head and cam set up on my ls1. numbers on my old motor was 435/405 on the dyno jet. 460 on the mustang is about 540 on the dyno jet. motor is a tsp 408 with there 250cc ls3 heads and 239/247 624 624 lsr cam.
Theblacknightls1
08-14-2012, 12:30 AM
What muffler you have? Very nice.. Numbers are great!
backdraft408
08-14-2012, 12:35 AM
mufflers are the ones that came with the kooks true duals
Stumbaugh
08-14-2012, 01:09 AM
Nice. Congrats. Any video's?
red fury
08-14-2012, 06:30 AM
Nice results, the graft looks really good!
backdraft408
08-14-2012, 08:17 AM
Vids will be coming soon. I like how the tq is right up there with the hp.
canada4g63
08-14-2012, 05:20 PM
Should pull hard mine makes a little more and is a blast to drive, was this on pump gas?
DietCoke
08-14-2012, 05:44 PM
Why meth? CR? I dont see 540 with those heads and that cam. Maybe 510 on a dynojet.
backdraft408
08-14-2012, 05:51 PM
All pulls were made with 91 pump gas
sasquatch
08-15-2012, 03:18 PM
Very Nice. I have a similar setup I will be putting together this weekend. Hope it comes out as good as yours
backdraft408
08-15-2012, 09:21 PM
what set up are you going with?
30th t/a
08-16-2012, 11:21 AM
Agreed.
Ive done back to back testing on a Dynojet & Mustang dyno and they were within 3rwhp of each other. Mustang dyno reading vary too much. If you want Dynojet number, put it on a Dynojet.
sasquatch
08-16-2012, 03:34 PM
TSP 408. 241 heads with 650 springs for now. comp 239/244 .624/.624 114 cam, 92/92 setup and 42lb injectors.
backdraft408
08-16-2012, 04:17 PM
sounds like a very good build. should get some great numbers
quik01ss
08-21-2012, 09:42 PM
More details what rear/ why meth?/ ported 102?
backdraft408
08-21-2012, 10:48 PM
tsp 408, s60 rear end 4:10s 12:1 compression. unported 102 but that will be ported in the near future. prc ls3 heads comp lsr cam 239/247 624 624, kooks true duals. went with meth for compression and cooler intake temps.
racerfox
08-22-2012, 01:30 AM
how are you on 12.1 on 91????
quik01ss
08-22-2012, 08:07 AM
Hmmm id think u see more power with those bigger heads but track times dont lie dyno numbers just a number...when i had my car tuned on a mustang dyno it made 520/474
-403ci, afr 225 big bore heads, 247-251 112 cam, unported 92/92, 1⅞ arh headers with y-pipe 3½ cutout s60 410s.
I havent redynod my car yet but ive changed to ported 102/102, 12.1 cr on 93, sd tuned, and kooks td system.
backdraft408
08-22-2012, 08:26 AM
methanol helps me out
backdraft408
08-22-2012, 08:34 AM
It was just the dyno is was on. that dyno reads really low. I going to be taking it to the track and drynojet soon. prob will see 540 to the tire on the jet. i know for a fact the numbers are low because my old h/c/i motor on the jet was 435/398 and i have tons more power with the stroker. I cant make any guesses on numbers without really seeing them but i shoulds be around 540/510rw. And the motor only had about 50 miles on it when dynoed. Have you had yours out to the track yet???
quik01ss
08-22-2012, 08:50 AM
On the old setup yes 1.8 60' 11.2@128 3765 weight me in car
backdraft408
08-22-2012, 09:07 AM
Im shooting for high 10s once i get the rear coilovers in
quik01ss
08-22-2012, 11:12 AM
Whats the size of those intake valves on those heads
djfury05
08-22-2012, 11:53 AM
I agree with others you won't see 540 on a DJ.. 510 was a good guess maybe 520 on a good day.
Forced_Induction
08-25-2012, 06:35 AM
For reference. I made 499rwhp on a Mustang dyno on my 402. I backed that up with 535rwhp uncorrected ona dynojet. That would be around 520rwhp corrected on the dynojet.
I think you'd be lucky to see 500rwhp.
Sales1@Texas-speed
08-25-2012, 10:48 AM
2.165 Intake Valve.
BADD SS
08-25-2012, 11:52 AM
I made 540/420 RWHP/tq on a mustang dyno with my high comp, high rpm 366, by your logic I would make ~620 on a dynojet? Thats absurd. I think you will pick up some, but not anywhere near what you think.
Mazzenger
08-25-2012, 12:14 PM
Hit me up if you ever take it to the track.
