tennerv8
08-14-2012, 01:24 AM
Hey guys. Had problems starting after my lq4 after it was warmed up. Couldnt figure it out. Switched base timing all around and all.
So the other day I pull into the garage after driving it a while and I noticed the rear pump squirter squirting fuel. Or percolating fuel. Mind you the truck was shut off. The fuel level looks fine. What else should I check? Is the fuel boiling?
