Generation IV Internal Engine - 199-PRC Deck Thickness
View Full Version : 199-PRC Deck Thickness
redriver racing
08-14-2012, 08:51 AM
What is the deck thickness on the 199-Prc l92 heads. My car for some reason keeps trying to lift the heads if u spray over a 150 shot. I used arp head bolts but not studs. Im thinking about upgrading my l92s which one should i go with.
416 ls3, fast 102, T/S 1.7/8 headers. T/S Cam. 11:1 comp
Would like to spray 250 shot without having any head problems.
Sales3@Texas-Speed
08-14-2012, 09:08 AM
If you are looking at our aftermarket casting PRC 250cc heads, they have a 3/4" deck thickness.
LSX-coupe
08-14-2012, 09:21 AM
You shouldn't be lifting heads at that HP level. I would switch to studs but we have sprayed 250 on bolts before with no problem. Is you timimg high?
redriver racing
The 199-prc is the heads i have now. was thinking about changing them up.
What is the stock l92 deck thickness? I would keep them if head studs would cure my problem but im not sure.
Sales2@Texas-speed
08-14-2012, 09:44 AM
GM head thickness is at or just a hair shy of .500". I would be suspicious of the block's surface finish RA, gasket selection, timing/tune-up, a number of things in the combo, etc before worrying about the heads thickness at that power level though!
redriver racing
08-14-2012, 10:24 AM
Everything is going to the machine shop to get cked out.
