Holley LS Fest - true street rules
sleeper101
08-14-2012, 09:40 AM
I read the rules and I'm confused on tires. in the advertisement part it states a dot legal tire. in the rules it says a true 10.5 tire. can we run a 10.5 slick?
Pro Stock John
08-14-2012, 10:01 AM
DOT tires only.
sleeper101
08-14-2012, 10:24 AM
So what class would my 240 fall under since real street is a gm chassis only class? I got a single power adder and 10.5 slicks? its a true street car. I drive it everywhere. I just don't have no drag radials.
s14blane
08-14-2012, 03:23 PM
6.D.O.T. Radials or D.O.T. Slicks on front and rear of vehicle.
Taken from the following link on the LS fest website:
http://www.holley.com/data/Pages/LSFest/Rules/2012%20LSX%20True%20Street%20Rules.pdf
1994z
08-14-2012, 05:33 PM
rumble class. if you have the time and money get a set of drag radials have them mounted on your wheels, run the true street class on sat. after the last pass take them to town and have them swap over to your slicks. if you want to go thru all that.
sleeper101
08-14-2012, 09:46 PM
Ya not really wanting to go thru all that trouble. Maybe someone will let me borrow some radials.
buick_lsx
08-15-2012, 02:14 AM
What's your bolt pattern and back space for the 240? And what size wheel
sleeper101
08-15-2012, 06:10 AM
4lug 4.5 bolt pattern. I'm using a universal mustang weld drag lite wheel 8in with 5.5 back spacing.
Pro Stock John
08-15-2012, 12:31 PM
What size slick are you running? Maybe someone has some DOT's they will sell cheap.
sleeper101
08-15-2012, 01:55 PM
26-10.5-15
s14blane
08-16-2012, 08:44 AM
There will be a tire changer on site for those who need to utilize that service. $10 a tire including tire disposal.
BLNLS1/RX7
08-16-2012, 03:35 PM
26-10.5-15
I might have a set of Hoosiers that size.I will chech.
s14blane
08-17-2012, 08:53 AM
I don't quote myself often but thought it important to mention that though the tire changer will be there he will not have access to a balancer, which makes this more inclined to the low speed events.
sw07gt
08-17-2012, 04:16 PM
DOT slick tires or DOT legal radials tires required for drive tires during the road tour AND the True Street competition and class run off. Racing slicks prohibited. Maximum actual measured tire size is as follows: Actual measured tread of all racing slick-type tire is limited to 10.75-inches. For D.O.T. radial tires, maximum sidewall designation permitted is 325mm.
I'm a little confused here, what qualifies as a dot slick tire vs a dot radial? Basically I'm trying to figure out if my 295 ET Streets are legal.
buick_lsx
08-17-2012, 06:39 PM
et streets? 3 grooves in the tread?.....LEGAL, they will have a dot number on them as well
Alvisracn
08-18-2012, 01:47 AM
I believe I have a set of those, if you can find some tires, I will check to make sure I have them and bring them with me.
Bill
sleeper101
08-18-2012, 07:16 AM
Bill
Sounds good man. I got a buddy here that has a set of radials on his truck he says I can borrow. so I should be ready I think lol.
