Stereo & Electronics - push button start install - plz help!
Numba20
08-14-2012, 09:46 AM
i ordered and recieved a universal push button start system. came with button, relay (4 pin 30A), cut on/off switch, and 3 aux switches. the button confuses me. it has 4 ports. i assume i will only be needing to use 3. which 3, is beyond me. electrical is on not my forte. that being said i followed the write up that a fellow member on here made. i believe the link for it was something like bowlings.com ? anyway he used a honda s2000 button, and did not install a cut on/off switch. i followed his directions as best i could as he wasnt as specific as i wouldve liked. but i believe all my wiring is right, minus maybe which wire goes to where on the relay, and in the back of the switches. i know that all of my connections and grounds are good. the first time i wired it up i followed his wiring diagram. which is this:
http://i780.photobucket.com/albums/yy90/numba20_photo/IMG_0404.jpg?t=1344920918
now this way did not work at all for me. i got nthing from the starter. and the LED lights in the switches and button did not work. i rewired it differently using this diagram:
http://i780.photobucket.com/albums/yy90/numba20_photo/IMG_0283.jpg?t=1344920909
now the LED lights work in the switches and button. but still nothing from the starter. ill give pics of my wiring.
http://i780.photobucket.com/albums/yy90/numba20_photo/IMG_0405.jpg?t=1344921037
http://i780.photobucket.com/albums/yy90/numba20_photo/IMG_0406.jpg?t=1344921033
http://i780.photobucket.com/albums/yy90/numba20_photo/IMG_0407.jpg?t=1344921094
but in my mind, here is what could possibly be wrong: the relay is no good. the button is no good. its wired wrong. im thinking that its the later of the 3. i know its not a fuse or the starter becuase i can hook the yellow wire back up and the car starts right up. some one please point out my mistake. (with the exception of buying the universal switch, or attempting to install it... for all you sarcastics out there)
pentavolvo
08-14-2012, 12:27 PM
can you hear the relay click when you hit start button, if not the relay isnt wired correct
Numba20
08-14-2012, 12:45 PM
No clicking, but when I test for current, I have my pin hooked to a ground, it will click when I touch the red wire (12v+ from batt) I guessed the ground was insaficcient. But I just made it impeckable, so it's not my ground either :/
Scoggin Dickey
08-14-2012, 01:04 PM
So the black wire goes directly to a ground, and the lighter blue wire across from it is being fed 12v from your button right? If it doesn't click, one of those isn't happening properly.
If it does click and doesn't start, I'd assume you have the wrong half of the cut yellow wire.
P.S. Your leg looks like it could belong to Sasquatch.
Numba20
08-14-2012, 01:05 PM
Found it! It was the freakin push start button! Faulty. And brand new...
02TransAm/Batmobile
08-19-2012, 02:19 AM
I have the S2000 push button start if you were interested. 50 shipped.
Numba20
08-20-2012, 02:43 PM
thanks for the offer but i alerady bought another one off ebay. and the seller of the faulty one is shipping me a new one free.
S8ER95Z
12-19-2012, 10:28 PM
Did you get this finished? Really curious how it turned out. Vid?
lemons12
12-19-2012, 10:58 PM
Where can i buy a push bottom kit at? Prices?
97FormulaWS-6
12-20-2012, 08:35 AM
Side note - Please please clean up that wiring, use the PROPER connectors!
Wire Nuts have NO PLACE in a car!
You're honestly asking to have a wire short, burn out, and light the car on fire with wiring like that.
Proper pre-insulated crimp connectors; and/or solder/heatshrink connections.
Numba20
12-28-2012, 02:27 AM
turned out great! ill try to take some pics of my switch panel soon for yall. never got any vids sorry.
get on ebay. there are a whole lot. good prices. dont cheap though, youll notice a difference in quality. i ended up buying 2 kits because i was so unhappy with the first. i tihnk my second kit i bough ran inbetween 60-80 but catnt say for sure. that was a while ago.
no worries. that was just for ease to get the system running. had a few different wiring maps, and didnt want any exposed wire in the trial period. all wiring has been soldered, and silicone shrink wrapped. DAD was an electrician. had him help me not to make a mess soldering. lol
and sorry response took so long. been up to my eyeballs in books. medical school isnt a benefactor for an aspiring hobbyist mechanic!
S8ER95Z
01-14-2013, 06:14 PM
All good man, please post some pics of the setup. I've wanted to do this forever.
Mista Blazer
01-15-2013, 01:30 PM
What is the safty feature on this? Id hate for Joe Shmoe to hop in my car and flip the switch ahah. this is a pretty bad ass idea in my opinion. i would do this! PLEASE show pictures when everything is finallized and a video! im really anxious!:hump::hump:
Numba20
01-16-2013, 10:20 PM
This weekend guys. Lol i literally just finished bedliner-ing the entire interior and i need new carpet and seats reaphulstered yet, but i have redone my switch panel yet again... And ive got to say... My pants get a bit tight when i think about this new set up. Its bad ass!!! Lol
Well im not sure about your car, but mine has the steering wheel lock. You still need the key to be able to steer or remove the car from park. Also ti wired the system to have to be turned on in accessory mode for the power to run. Thirdly i have a safety switch. Lol it may be a bit impractical in this sense, but still cool factor has enponentialized all the same. Lol give me until friday. I will deliver possibly the coolest/(not overly done)/classy switch panel an ls1 transam has ever seen.
Mista Blazer
01-17-2013, 07:31 AM
That's actually pretty nice, I thought you had some special voodoo that you use.to.get it to start ;D so all you gotta do is.insert key rotate to accessory and push the.button? I think I will be down for that! And if the panel looks good I may just pay you to Fab me.one :D
Numba20
01-17-2013, 05:16 PM
Yeah its pretty simple. Lol and it aint hard to do! Just get a small sheet of galvanized metal, cut your holes, and paint it to match, put in the switches and wire it up!
Numba20
01-17-2013, 08:03 PM
http://i780.photobucket.com/albums/yy90/numba20_photo/A22E71A1-2989-43FE-BE14-5F278E641D1C-8602-0000067A45C06E64.jpg
http://i780.photobucket.com/albums/yy90/numba20_photo/CD86B4A4-375F-4FF1-B59F-2B7CA7261555-8602-0000067A3F232100.jpg
Bedliner is slopped on. I need to clean it up, and car is in pieces, but the plate is in. Ill get a vid up for yall sometime this weekend. And ill explain and depict my set up for yall if you want to steal some ideas. Lol
Black_Z28
01-18-2013, 01:22 AM
Umm, you put bedliner on the interior panels? Wow, that's unique...and I don't like. I thought you were doing the interior metal, to help with sound deadening.
But, to each their own.
Numba20
01-18-2013, 05:04 PM
Pics dont realy do it justice... Its will look like regular black interior with a bit of a rougher texture when i finish. Its virtually bullet proof, water proof and wont allow anything to crack. Plus u can cover everything for around $100. Ill just need carpet and seats redone. And if for some reason any is ever scraped off, touch ups are a breeze.
chaman
01-18-2013, 05:16 PM
Bedliner? Why? Why? Blows my mind....
Numba20
01-18-2013, 08:46 PM
Well grey with red trim and seat inserts just wasnt cutting it with the new yellow paint. So... Lol i had 3/4 a gallon left after doing my truck bed, seen how good the finish was, and thought, it isnt going to cost me anything except time, and ill part this interior out and probably throw away the other half of what i dont sell, so why not? Either way, black interior is what itll be. I had been eyeballing it and was really concerned with the finish. (didnt lay quite as smooth on plastic as it did on sanded down truck bed.) so i did sone touch ups in spots, then wanted to try some interior shines, its ridged so its hard to apply with a rag... But i had the idea of tire shine, and ohh boy, i have to say i will glady take credit for this idea! Im happy with it, and im a total anal OCD guy when it comes to things with my car. (finished products. I let works in progress slide a bit. Lol)
Numba20
01-18-2013, 08:58 PM
Here is a pic of the door panel after it got some shine on it.
http://i780.photobucket.com/albums/yy90/numba20_photo/AB7072C7-5A2D-4DBA-B1EF-06F84BE8D3F1-9820-000007938635D830.jpg
And here is a closer pic of the same panel. In truth, it looks better in person than in this pic. I believe the pic above does it justice. I think it may be the flash. All the same. It doesnt look terrible. And once i get it all put back and finished, and cleaned up, then most wont be able to tell that anything has been done. Youll need a second look anyway. Unless uput your face 12" in from the surface.
http://i780.photobucket.com/albums/yy90/numba20_photo/64A6A775-35C3-4F79-A3B5-657999EFBA0E-9820-0000079390E2030E.jpg
'02 WS6
01-19-2013, 12:55 AM
Are you planning on sanding the crap out of all your panels? It may look better in person but bedliner has always felt horrible to touch IMO. Truth be told, there are interior parts ALL over eBay and Craigslist.
Numba20
01-19-2013, 08:45 AM
I just wanted to give this a try. If im not pleased with any aspect, then ill be ginding myself a complete factory black interior.
Numba20
01-21-2013, 06:02 PM
I got the vid and a couple better pics... But cant seem to upload it to photobucket (the vid only) im trying to do this from my iPhone. Any one know of another way to get that vid up? .... just put it on YouTube. i just watched it too. and im tough tied and breathing heavy! lol! i had been hard at work scrubbing the piss out of my windows. dad gum overspray got on them some how.
www.youtube.com/watch?v=0LR6u3LWeck
http://i780.photobucket.com/albums/yy90/numba20_photo/F876E9F0-AAB1-4787-BBD3-F29A7D231D65-12268-00000A68B3CA9C1F.jpg
http://i780.photobucket.com/albums/yy90/numba20_photo/3B3C9D48-8CEC-4079-A401-1FD529CD6BED-12268-00000A68BDD46F0B.jpg
Numba20
01-21-2013, 07:21 PM
update. got that vid up!
Mista Blazer
01-21-2013, 10:04 PM
At first I thought all your plastic.molding had caught fire at one point till I read more and saw you did bed liner xD its interesting!
Numba20
01-21-2013, 11:31 PM
Lol! While i can see the resemblance, its not quite that bad. Stoll looks best in person. And if a coat of some type of oil base product is applied, and its deep black, and shiny, it really looks good! :eyes:
