Pontiac GTO 2004-2006 - manual brakes?
96s-10ss
08-14-2012, 10:57 AM
does anybody make a manual break setup for the 2004-2006 gto?
mark21742
08-14-2012, 12:18 PM
I made my own kit with a wilwood master, 14" drilled and slotted 2011 Camaro rotors, Cadillac cts-v 4 piston calipers in the front and moved the stock GTO 2 piston calipers to the rear...just had to make a few adapter plates and brackets, then slightly modify the rear parking brake shoe
96s-10ss
08-14-2012, 06:06 PM
Hmm interesting
svede1212
08-14-2012, 08:42 PM
My automatic brakes must be broken. I keep having to press the pedal. . .
96s-10ss
08-18-2012, 07:19 PM
Har har har
torridred04goat
09-03-2012, 10:27 PM
Yes they do have a manual brake kit for the gto. it is usually used for cars with big cams that dont provide solid vacuum. i think walt made it. cant really remember ill look it up and post back
Robofuzz
09-04-2012, 12:38 PM
I'm interested in how you adapted the front calipers to the back. Any pics or info on that conversion?
mark21742
09-05-2012, 10:40 AM
I used the 2011 Camaro 14" rear brake rotors and even running 18" wheels i had to FI a LOT of grinding on the back side of the caliper to get it to just clear the inside of my wheel...after the rotors isbolted in place with the lug nuts I just dropped the factory GTO front calipers on the rotors and made an adapter plate out of 3/8" plate steel.
Robofuzz
09-05-2012, 10:56 AM
I assume you had to machine the center bore a little bit to get the rotor to fit?
mark21742
09-05-2012, 11:39 AM
Front or rear, I can't remember which one, one slid right on, bit had to do a little dremel work on the center of the other set of rotors to get them to slide on....sorry I forgot about that lol I did mine about 3 years ago.
Also on the rear I used the gto parking brake shoe but I had to cut a slot at the top a and pull the two sides apart a hair, welded the slot shut again and welded bigger gave on the ends at the bottom where the adjuster/ pull meets the shoe. The Camaro shoe is just a little bigger than the GTO shoe.
JNR_Design
10-03-2012, 03:09 PM
don't mean to come across as an ass, but why the hell would you do manual?
If it's a vacuum issue, then convert it to a hydraboost system (uses hydraulics from PS pump, splice in so to speak [so you still have PS]); it was a factory offering in some GM cars and many of the diesels, so you could do that way or they have aftermarket ones also. superior to a typical brake booster that uses vacuum and it doesn't take up much more diameter then the master cyinder outline.
2nd option if you don't have or want PS, is an electric vacuum pump, like the ones they used on RV's, some diesels and IIRC some of the cars.
3rd option is a vaccum reservoir canister. However, the problem with these is they give you 1-2 successive stabs before you lose vacuum. Not a problem unless you're in heavy stop and go, but it was a PITA enough for me to ditch that on my chevelle (it only puts out 10-12" HC @ 1k rpm, sea level) and get a hydraboost system.
JCR Chassisworks
12-01-2012, 07:52 PM
Dear JCR Chassisworks,
You have received an infraction at LS1TECH.
Reason: Non-Sponsor Soliciting
LOL. I one of your members who you should want to help asked if there was anything available to which I replied. One also asked for price. To which I privately replied. I solicited nothing. When someone who means well and offers to help your members and gets a response like yours LS1, I'll give you my response. Take your comi site and stuff it. Delete my account ASAP so you don't claim additional members that you don't have. Thank you.
1INSANEGTO
12-01-2012, 11:07 PM
Guys I had this done years ago. Even have a built in line lock.
Eat your hearts out.
http://i759.photobucket.com/albums/xx233/1INSANEGTO/DSC02840.jpg
http://i759.photobucket.com/albums/xx233/1INSANEGTO/DSC02841.jpg
http://i759.photobucket.com/albums/xx233/1INSANEGTO/DSC02842.jpg
