Stereo & Electronics - Immobalizer issue
champain
08-14-2012, 12:06 PM
I am having some issues with my immobalizer. it is a "gm accesories" immobalizer, pretty sure it was put on by the dealership. 1998 trans am is what its in. The way it works is I swipe this fob close to the shifter and then it beeps, then i can start it. The problem is , it is very inconsistant and i can sit for a hour sometimes swiping away until it beeps. Any one have experience taking these things out? looking for a write up or some info on how complicated this thing is to remove/bypass. The reason i want to remove it is because i went to the dealership and they said they no longer have this item and i can not order new fobs.
thanks
sbcnotch93
08-14-2012, 02:12 PM
The easiest way to remove this piece is to follow the 2 wires that will be hooked to your starter wire of the car (which is a 12g yellow wire). Your yellow starter wire will be cut in half, with the cut ends being hooked up to a wire coming from the GM piece. Just cut those 2 wires, and reconnect them back together, basically eliminating the GM security piece and putting your starter wire back together.
The GM system is basically acting as a starter kill. Simple circuit.
champain
08-14-2012, 02:19 PM
thank you sir i will give that a try!
champain
08-14-2012, 02:20 PM
will there be other wires like ground or power? dont wanna start it and have a nice surprise
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
