Does anyone have a VE table for a 427 with a fairly large cam that they could share?
Old 08-14-2012, 12:24 PM
Bill00Formula's Avatar
Default Does anyone have a VE table for a 427 with a fairly large cam that they could share?
I have efi live and am trying to tune my car (I have let it sit for a while so I haven't done much recently) and just wanted to know what, appoximately, I should end up with. Not sure it matters but I have 4" stroke, 4.125" bore and TFS 235s for heads. Also, I'm not using percentages for values but I guess that's easy to change. Thanks
Old 08-14-2012, 07:02 PM
BLK02WS6's Avatar
Do you have a wideband? What injectors are you running? SD or MAF tune?
Old 08-14-2012, 09:06 PM
When I started/attempted to tune it I installed a wideband. The car was professionally tuned but the VE table wasn't touched above 2,000 rpm (stock). The MAF was setup to come on at 2,000 rpm. From what I understand the VE table is how you get crisp transition response. I do plan to use the MAF as well.
Old 08-15-2012, 05:24 AM
BLK02WS6's Avatar
To be done correctly, the entire VE table should be tuned with a wideband - as well as the MAF table...
