Stereo & Electronics - alpine type R thin?
exodus_gs1
08-14-2012, 10:16 PM
Anybody using this? I wanna get a stealth box and a friend said I needed a bigger box for my type of music. So I thought maybe a thin sub would give me the extra room. Anybody have experience with this sub or any other "thin" sub?
Snake_Skinner
08-14-2012, 11:01 PM
Whats wrong with a normal Type R, it'l fit? Truthfully no sub is going to give you the "extra room" in a stealth box, there just too damn small.
exodus_gs1
08-15-2012, 03:28 PM
nothing just the width. Because subs need that air and I thought with a thinner sub there would be more room meaning more air
blown97ss
08-16-2012, 01:17 PM
I had a 10inch type r in my old car sounded good for rap music. My buddy the guy that bought the car listened to rock and it sounds good he likes it a lot. It's not going to be a supper loud bass but it will shake stuff around.
exodus_gs1
08-16-2012, 02:33 PM
Well hell yea, cause I listen to mainly rock and metal, my wife likes rap... But anyways lol. So was that in a stealth box?
I use to have just type R speakers in my srt4 and a stock head unit and it rattled stuff, then had two type R 12's in my Lexus and that was nuts. So I hope combining the two will do good
NeedAName
08-18-2012, 11:12 AM
Subs do need air to make music, but the fact that it is thin and thus has more available air does not automatically necessitate that it will be louder. Look at the recommended box sizes for various subs and see which subs will function good in the space you have available.
Additionally, putting more power to it could help to compensate.
exodus_gs1
08-18-2012, 11:50 AM
Since when? You need that air space, thats why most sub boxes are so big. My cousin use to build boxes for competition cars and they where always big. Why else would people give up there entire trunk for the box, if it made no difference.
NeedAName
08-18-2012, 01:34 PM
I'm not sure what exactly you're asking about when you say "since when" ?
I know you need air space, but different sizes elicit different results. You can have a box that's too small, and similarly you can have boxes that are too big. In competitions, the subwoofers that are utilized to achieve high SPL levels (read: get loud) are best suited in larger boxes. Certain subs work better in certain enclosures.
Your best bet is to look at how much cuft. is available in the stealth box, or whatever box you're looking to get and then to see what subs work good in that size.
For example, if you go to JL's website and look at the page for the W6v2, it reads "The 10W6v2 is best used with amplifier power in the 200W - 600W range and is optimized to operate in a 0.625 cu. ft. (17.7 l) sealed enclosure, or a 0.75 cu. ft. (21.2 l) ported enclosure. Detailed enclosure recommendations can be found in the "Specifications" tab."
exodus_gs1
08-18-2012, 06:43 PM
The since when was a mistake. I miss read your post cause im a dumbass. But thanks for the info. And the box isn't very big, idk if you have seen the stealth box but it's just big enough for a 10" woofer. But ill look at jl's site
Snake_Skinner
08-18-2012, 07:18 PM
this subs seems to be quite expensive, where are you finding it for a descent price?
blown97ss
08-18-2012, 10:42 PM
yes it was on a stealth box powered by a 500x1 fosgate amp
exodus_gs1
08-19-2012, 03:20 PM
Yea I know it is, I haven't looked much into it yet, i was going to ask around on here and do some more research. I know jl makes a thin sub also but i think it is just as expensive.
ok hell yea
Adam1982
08-24-2012, 06:27 PM
Don't get a thin sub, there are plenty regular subs that work well in stealth boxes. The recommended sealed volume for the thin type r is .35 cu ft, most stealth boxes are about .6 cu ft, and its way to damn expensive. If you want a type r, go with the regular, although a lot of people don't like type r's in sealed enclosures and I agree, but it may work for you.
exodus_gs1
08-25-2012, 12:23 AM
How does the extra space harm the sound? I'm no expert that why I ask. I have built a few boxes and installed plenty, and what's the sound difference between sealed and ported? I didn't put much thought into that. Is there away to port a stealth box?
Adam1982
08-25-2012, 10:26 AM
Because you cant just build a giant box, put any random speaker in it and think that its good. You say you build a few boxes, did you go by the recommended enclosure volume or did you just build a big box and cut a hole and screw a speaker in it? The reason "competition" boxes are so massive is because they are housing internal ports, the size and length of which determine what freq. the box is tuned to. Bigger doesn't mean better, it needs to be optimized for what speaker(s) you will be using, which is what you should figure out first. Can you port a stealth box, internally...no. Can you modify to run an external port....probably but its a lot of work to make something that will take up a lot more space and look ridiculous. The other option would be to use a passive radiator, even that may be too much work to retrofit into a premade stealth box. If it matters that much, do some reading http://www.soundsolutionsaudio.com/forum/ is a good place to start. If not then just get a stealth box, whatever 10" that will work with .6 cubes and an amp to match and enjoy it.
Here's a thread on a passive radiator set up, http://www.soundsolutionsaudio.com/forum/topic/52747-got-my-psi-passive-radiator-what-for/page__hl__%20passive%20%20radiator
PR vid
http://www.youtube.com/watch?v=9k6b5kx6NWY&feature=player_embedded
exodus_gs1
09-01-2012, 12:11 PM
ok cool thanks man, yea the boxes I have built were not my design. Few times helped my cousin and twice with my stepdad all of which they had a pre determined layout. But from what I could tell they were just basic. The most recent was with my stepdad. We built pretty much just a big rectangle with a "muffler" set up. It had two dividers in it that was half the height and the full length. One mounted to the top the other to the bottom on either side of the sub a few inches away. And with a type s 12 it rattles my sisters Tiburon when the bass is all the way up. But idk if he found the design online or just went with it. But thanks for all the info and reading material.
bill12690
09-02-2012, 01:13 PM
I have the JL 10w3 in mine, honestly no complaints at all... I love it, and have plenty of room for whatever in the hatch. Its decently loud, and sounds good.
exodus_gs1
09-02-2012, 01:50 PM
You running the stealth box?
bill12690
09-02-2012, 07:46 PM
Yup. Got the JL 10w3 and stealth box from DoubleD mods..
exodus_gs1
09-03-2012, 02:35 PM
Cool thanks man
Adam1982
09-03-2012, 02:46 PM
A lot of people seem to like the 10w3 in the sealed box more than the type r
