Fueling & Injection - boost reference regulator leaking
a4ls2goat
08-14-2012, 11:49 PM
I'm having a issue with my regulator.
Everytime I rev the motor passed 4k rpm or so the boost reference nipple on the regulator spills a little bit of fuel. It's not a lot but it does seep out under load.
It does not leak while normal driving.
My fuel pressure is solid at 62psi and does not drop.
The regulator is a SUMMIT boost referenced regulator.
What can be causing this?
Lonnies Performance
08-15-2012, 06:18 PM
Most likely the diaphragm is bad in the regulator.
98Camarod
08-15-2012, 06:48 PM
are you boosted and it stays at 62psi?
a4ls2goat
08-15-2012, 09:40 PM
that would suck, as its a new regulator
a4ls2goat
08-15-2012, 09:41 PM
yes it does
98Camarod
08-16-2012, 04:22 AM
yes it does
It should rise 1lb per 1lb of boost. something doesn't sound right.
a4ls2goat
08-16-2012, 07:14 AM
Obviously I can't see if it leaks under WOT while driving.
This is if you rev it while parked.
salemetro
08-16-2012, 10:36 AM
It should not leak at all...ever.......time to return it.
Edit: It also sounds as if you don't even have the reference port hooked up....as you're able to see a leak out of the reference port. As has been said previously, fuel pressure should rise 1lb per lb of manifold pressure increase.
a4ls2goat
08-16-2012, 10:49 PM
i dont have the reference port connected because im currently not going WOT.
and i know if i hook up the port it will rise 1lb per psi.
a4ls2goat
08-20-2012, 03:59 PM
Called up summit racing.
They are sending me a new one even though it was out of warrenty
MIGHTYMOUSE
08-22-2012, 01:03 PM
never should be fuel on the air side.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
