Snyper
08-15-2012, 01:10 AM
This problem is killing me. Ive tried +/- 10* of timing..and have added enough fuel to fill a small pool and it doesnt change a thing. The car runs PERFECT from idle to about 2k...from there the car runs like shit till 3k..sometimes I watch AFR shoot to 19-20 and it sounds like the engine isn't getting any fuel..other times it will be in the 13-14afr range and the more load I put on the engine (MOSTLY at the 24-2800rpm range) the car will break up bad..as soon as it hits 3k..its cleans up completely. Engine is an ERL 434ci 11.8:1 compression with a massive 262/266 .624/.624@113+3 cam and a fast 102. The block was milled once when it was rebuilt the first time and again when it was sleeved.
At first I thought it was my intake because I was seeing mid 80s KPA at idle..so I switched to a stock LS2 intake and the problem stayed the same along with the vacuum (or major lack there of). It happens whether im in MAF, SD or Hybrid mode.
Plugs are NGks gapped at .045, MSD wires, stock coils with new wire harness on coils. I took the plugs and wires off and found a loose plug..so I tightened it up put all the coils and wires back on and the problem seems to be a little more pronounced now.
I did a compression test today so far (leak down tomorow) and saw 182-185psi (cold..maybe 100*) across the board.
Can anyone give me a possible cause for this? No matter what I do..its only in the 2-3k range and completely clears up after 3 every single time...along with it going to 20afr sometimes always at the same load/rpm..no matter how much fuel I add to it.
