Tps codes help
Old 08-15-2012, 08:16 AM
DPRock's Avatar
Default Tps codes help
This is what it reads with no throttle pressed.
This is with the throttle pressed.
Should I just try a new tps sensor ?
Old 08-15-2012, 01:39 PM
SSHAWK's Avatar
Just set your car on fire….. it will fix your problem David. lol
Old 08-15-2012, 02:24 PM
YellowTA1's Avatar
that's way harsh sean
Old 08-15-2012, 05:58 PM
DPRock's Avatar
It's fixed guys I found the problem 5 mins after I posted. And for you Sean give me more time and I'll smoke your ***.
Old 08-15-2012, 10:02 PM
SSHAWK's Avatar
Hell you should be able to do that now.. My ****'s a stock 5.7!!
We should run them next week.. I can't see my car beating you with all the stuff done to yours.
Old 08-15-2012, 11:03 PM
JMAC's Avatar
Good you fixed it Dave.
OH yeah I got the winner when my heap gets going
Old 08-16-2012, 06:57 AM
DPRock's Avatar
I need tires Sean but my car money is low right now.
Old 08-16-2012, 05:15 PM
DPRock's Avatar
If somebody wants to loan me some rubber I'll run you next week. Sean I may have this nice motor setup but I'm heavier and have less suspension mods.
Old 08-16-2012, 05:16 PM
SSHAWK's Avatar
lol Looks like you will be racing David lol
You should run my buddys car "Rob" he just finished his motor too. Jerry knows the car I'm talking about.
I think he has the same mods as you do..
But I'm down for a run.. Just whatever you do don't let me beat you on motor lol
Old 08-17-2012, 03:57 PM
mike171562's Avatar
so, what was the problem?
Old 08-18-2012, 06:21 PM
DPRock's Avatar
Mike I'm thinking it was my cheap eBay throttle body. I noticed the adjustment screw been chipping away at the throttle body area that it stops on. And from doing so a little piece was stuck on the tip of the adjustment screw. Which in return was causing the tps sensor to read wrong and causing the car to idle high. I'll post pics later on what I'm talking about.
Old 08-19-2012, 02:16 PM
jb7241986's Avatar
you wanted to save money on ebay look what it gave yoooooouuuu
Old 08-19-2012, 04:56 PM
bigantws6's Avatar
What did u do to fix it i replaced my tps and still throwing code on hptuner it jump from 0 to 20 like its dead in between those number
Old 08-19-2012, 06:06 PM
DPRock's Avatar
Sorry pic taking with phone. Bigantws6 the adjustment screw is chipping away at the surface it stops on. The tip of the screw had a nice size aluminum chip on it causing it to read 17% closed throttle. I filed the surface smooth and the tip of the screw. It then was reading 3% closed throttle. I tried to adjust the screw but it wouldn't drop to 0% closed throttle. So I looked closer to the tps sensor I drilled the holes bigger so I could adjust it. Now it reads 0% closed and 99% full throttle. I have over 100 miles since the fix and still reads perfect and no codes.
Quick Reply: Tps codes help
