Generation IV Internal Engine - Double Roller timing chain.........which one to get?
LS6427
08-15-2012, 07:02 PM
LQ9 (GIII) 390ci......single turbo.....1,000+ RWHP
Is the SLP double chain any good? I have no idea about chains.....
I searched google and couldn't find much.
Thanks.
litle88
08-17-2012, 06:44 PM
Just call katech for their C5r timing chains. You'll be all good and won't need any spacers or grinding of timing cover to make it fit. G/L bud
DietCoke
08-17-2012, 08:08 PM
I've got a rollmaster double. Awesome quality for $65
01wss6
08-17-2012, 10:56 PM
I bought the SLP pump and double roller chain and didn't have any problems. I bought those so I didn't have to worry about an oil pump not working with a different chain.
LS6427
08-17-2012, 11:58 PM
Man...tried to look it up on their site........their site blows.....
Can you tell me what that C5r double chain costs?
DietCoke
08-18-2012, 12:09 AM
c5r chain is a single and runs 150ish
LS6427
08-18-2012, 12:12 AM
I see a guy sells that same exact Katech chain for like $111.00 shipped. From Australia. Katech buys them from them. Chain is actually made in Germany.
Or just buy the C5R chain for $60.00.
I emailed John Loyd over there just now to get a price shipped....
streetquick@bigpond.com.au
ramairws6
08-18-2012, 10:59 AM
Be carefull, there are C5R copycats chains out there. Just be aware...
djfury05
08-18-2012, 12:32 PM
I would suck it up and order directly from Katech.
3rdCoastPowerSports
08-18-2012, 01:56 PM
I agree
Also you do not need a double chain. I don't really get why people want to run double chains they cause clearance issues and im pretty sure they arnt any stronger.
litle88
08-18-2012, 02:10 PM
Dbl roller timing chains are so Chevy 350's lol
DietCoke
08-18-2012, 11:28 PM
I agree
They're twice as strong. Probably something to do with having twice the chain.
:jest:
They've got 3 links instead of two, so they're probably 50% stronger then a single. Sure they cause clearance issues, but that's part of building any engine. You have to make stuff fit... OR pay more for an inferior piece. Either way its moot because LS engines don't regularly throw chains unless there's another issue entirely
SS10Tech
08-18-2012, 11:55 PM
Double rollers do show benefits once you are working with a heavier valvetrain - especially big blocks and hard launches. I would suggest the Katech chains for an LS application, i believe they are the only company that can boast no breaks caused by the chain itself ever in the history of their design. Pretty impressive to say the least!
stevieturbo
08-26-2012, 03:31 PM
John at Streetquick builds only top quality stuff, you can be sure whatever he is selling is quality
willyfastz
08-26-2012, 03:38 PM
http://www.progearweb.com/4000/pg4210.htm
Strong and accurate
stevieturbo
08-26-2012, 03:43 PM
Although should add I am just using a Comp Cams double roller.
