Gears & Axles - Looking to get a set of 3.73's, what all do I need?
mcalus
08-15-2012, 07:48 PM
Sorry I'm sure this question has been beaten to death but, what all do I need?
I got a buddy that build my trans and he said he can install my gears I just need to supply everything.
What brand should I get?
Is 75w90 sufficient? How many quarts?
I only need 1 GM additive correct?
What install kit should I get?
Links? Sponsors?
Thanks all :)
Car is a 93, 2 series rear.
1981TA
08-15-2012, 08:25 PM
Links? Sponsors?
Thanks all :)
I guess some more info is needed. Are you experiencing any problems (noise, vibration, etc)? What do you ultimately plan to do with the car (drag race, DD, road race, add horse power, trans swap, etc)? I'm pretty certain there are other parts you'll want to replace while you're digging around in there. Several factors have a bearing on this. The answers for staying at stock HP levels and DD-only would be very different from going full race.
With the build I see in your sig, you're going to need more than a ring and pinion.
mcalus
08-15-2012, 09:05 PM
It's a drag race / weekend car. I drive the car to work once a week TOPS.
Mods are in sig, new rebuild has ~600 miles on it.
No vibrations or noises. Around 50-55mph im around ~1000-1100 iirc.
I'm not looking to drop tons of cash in the rear as I may sell the car or upgrade to a 12 bolt.
zman1969
08-17-2012, 11:08 AM
good used GM gears are around ebay, your local Pick and pull - look for s10 4x4 blazers shouldnt cost more than 50-80$
good lube 2quarts needed
intsall kit with bower aor preferably Timken bearings
mcalus
08-17-2012, 09:14 PM
Links for install kit? Thanks for the info
mcalus
09-30-2012, 04:05 PM
Worth it?
http://m.summitracing.com/parts/MGR-G875373X
Looking to get everything I need as soon as I can. Going to TNT before winter.
Thanks!!
01ssreda4
10-01-2012, 12:19 AM
Gears of choice, I prefer Motive blue box
Ratech 308tk rebuild kit
2 quarts of syn oil (has additive already in it)
mcalus
10-20-2012, 07:45 PM
Buddy upgraded to a 12 bolt. Has his Detroit tru trac for $200 with a set of hardend axles. Worth it?
Bob@BruteSpeed
10-22-2012, 07:09 AM
Since you're running an automatic, the rear stands a chance of holding together. I'd say go for that Truetrac and axles. Bob
mcalus
11-24-2012, 08:50 AM
Sponsors have any gear specials going on? Looking to buy today!!
mcalus
11-25-2012, 10:41 AM
Where can I get the blue box gm ones? I can only find the g8's.
