Cadillac CTS-V - TVS from 2008 G8 GT
FuzzyLog1c
08-15-2012, 10:09 PM
Someone made me an offer of $4500 for a used Magnacharger TVS1900 for my LS2 CTS-V. The kit is off a 2008 G8 GT, which I believe has a L76 engine.
Any idea if this would work without fabricating any new parts? Based on a little research, it seems that I'd have to spend about $1000 on a set of L76 rectangular port heads and offset rocker arms, but other than that, everything looks fairly straightforward.
racermike68
08-15-2012, 10:23 PM
That and $4000+ for the 8.8 rear end you'll need...
FuzzyLog1c
08-15-2012, 10:43 PM
Not with the stock LS7 clutch slipping every time I try to lay 525 RWHP on the ground. :eyes:
While I'm at it, any thoughts about whether it's even worth looking at an old Maggie?
98cobra
08-16-2012, 12:57 AM
That would work with my ls3 heads. Tell him I have $3500 on it =)
Keep in mind that you will also have to source the additional parts to make it work. Also, you will have to get an LS3 waterpump to work with the tensioner.
The G8 belt config is the same, but that is about it. All told, you will probably have twice as much in the used TVS1900 as I will with my E Force 2300 when its done...using 243 cathedral heads.
Greed4Speed
08-16-2012, 10:18 AM
I'd do a cam change while the heads were off.
shadyLS6
08-16-2012, 10:38 AM
WHAAAAAAA!!! Using 243 heads! Any thread on this?? i need to put my 8.8 to use hahah
On my way home from Cozumel at the moment, hopefully it is waiting for me since it was supposed to ship this week. I will def start a thread when I start the project though.
wcryan
08-16-2012, 11:34 AM
All I know is that the eforce fits on ls3 heads. And ls3 heads will fit on an ls2. I kick myself in the ass for not going that route
lollygagger8
08-16-2012, 12:37 PM
I'm not even done with my N/A build, and I'll be watching that Eforce thread when you start it DMM.
psychobillycaddy
08-16-2012, 01:09 PM
not so - the e-force can be ordered with Cathedral ports for LS2 heads. You just have to tell them when ordering so they will forge it that way.
s-cam
08-18-2012, 05:07 PM
The pulley routing on the front of the blower has to be modified or a different water pump has to be used if you want to use the g8 tensioner pulley set up.
RADEoN
08-19-2012, 08:20 AM
243 casting heads (ls6/ls2) are cathedral port, LS3 heads are square.
