Generation IV External Engine - ls3 in my 02 ws6, whats it gonna take
Raptor_WS6
08-16-2012, 01:53 AM
so after dropping a lifter in my cam only ls1 that made 412/403 top the wheels at its prime i replaced it with a stock lq4 w/ epp boost cam, slp dbl roller, ls7 lifters, slp pump and katech rod bolts, that lasted a year,
i was racing a friend in his turbo camaro and the motor seized up, was having some oil pressure issues,
the next day it started but made all kinds of weird noises.
now i want to go back to aluminum and want an ls3
what do i need to make it work with my car (stock harness and pcm)
HerbCunliffe
08-16-2012, 03:38 AM
I've done it. Just a few minor things, the Lingenfelter 58x-24x box, and tune.
Raptor_WS6
08-16-2012, 08:49 AM
Can I just put a.24x wheel on it?
What about knock sensors and.cam sensors and such..
isn't there a new sensor in the front cover?!?
DANSBIRD
08-16-2012, 12:45 PM
I'm doing the same swap now and from what I understand, if you want to swap the wheel, you have to take the engine apart and it's more expensive, more of a hassle than it's worth, unless you're building the motor from scratch.
DANSBIRD
details on your swap? what all did you do to the engine? I think I have the cam specked out that I want to go w/.
HerbCunliffe
08-16-2012, 02:57 PM
Short rundown; Picked up a zero mile LS3 short block on fleabay. Took the rods and pistons out, ARP2000 rod bolts checked and installed. Piston rings gapped(stock was .006 on the top ring :doublepuk ) I didn't want to go further on a stock motor so the 58x wheel stayed in. SDPC LS3 heads and PRC spring kit. checked my pushrod length to put me .06 preloading the lifter on a custom 3 bolt cam on LSR lobes. If you use the 58x box make sure you have the 3 bolt 4 bump timing gear. Cleaned up the heads a little but nothing that would affect port velocity. Then topped with a complete intake/rails/injectors from fleabay. You wouldn't believe the final cost;)
Knock sensors were moved to the side of the block and map sensor RTV'd and held down on the front of the intake so the computer is happy.
Hope this helps, I am not good at the internet/ wish I knew how to put pics up
DANSBIRD
08-16-2012, 03:26 PM
Ha... for the effort, I'll tell you how to post pics. If you can, upload them to a hosting site, photobucket, etc... (I use imageshack.us), you'll see a link for the picture called "Direct Link". Copy this link and past it in the post. Once it's in the post, surround the link with image tags. It's [ img]directlink[ /img] and remove the spaces after the brackets. (I put the spaces there for this explanation as if I didn't add the spaces, the text would disappear as it'd think I was inserting an image.).
Streetrodengines
08-16-2012, 05:34 PM
Use injector adapters, cam trigger extension, map wiring extension, 5 wire 2002 Vett mass air flow with adapter and use a custom built LS3 with a 24 tooth crank. Re tune the computer for LS3 with five wire maf.
Raptor_WS6
08-16-2012, 07:09 PM
I already haf a vette maf with the Casper adapter.
so I will need
injector adapters
cam sensor adaptor/extension
58x adapter if I don't use a 24x wheel
is that it?!!
I wanna use the ls3 intake so I should get a 90/92mm dbc tb right?!?
Posted from LS1Tech.com App for Android
Raptor_WS6
08-16-2012, 07:10 PM
so I will need
injector adapters
is that it?!!
and fuel rails from ls3.
can I use my stock coils?!?
rumblebox
08-20-2012, 10:13 AM
throttle body cable adapter.
STLSleeper
08-29-2012, 09:56 PM
I am putting a brand new crate ls3 in my 2001 camaro. Here is a list of everything I have bought.
1.) Katech cam sensor extention harness
2.) Lingenfelter 58-24 trigger box
3.)ev1-ev6 fuel injector adapters
4.) Ls1 balancer and crank bolt
5.)90mm cable throttle body
6.) Slp Throttle cable bracket
7.) 85mm corvette maf
8.) 5 wire to 3 wire maf adapter
9.) Katech knock sensor extentions
10.) Ls1 windage tray, oil pan, and pick up tube
11.) Ls1 water pump
