Project66impala
08-16-2012, 05:59 PM
I had a aftermarket oil pressure switch installed on the motor and the computerwas saying i had 18-20 psi at idle and 35 at wide open throttle...so i changed out that sensor and installed an autometer gauge and sending unit and says my oil pressure now is 25 at idle and 50 at wide open throttle..is that pressure safe? Or should i look into changing the pump?
