FS- HSW Interface & Microedge Plus Controllers
Category: Accessories
Price: $0
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): TX
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
HSW Microedge Plus controller $200 shipped
This was very nice to have
Very clean without scratches
Here is what it features
Dual Stage RPM Window Switch,TPS Activation Switch,A/F Safety, progressive controls, Shut Down Switch
Used HSW Interface 175.00 shipped
HSW Description: Introducing the world's first Air to Fuel nitrous controller; The HSW Interface. With The Interface controller you can now easily fine tune your air to fuel mixture without the hassle of swapping fuel jets or worrying about the nozzle placement in relation to the MAF sensor on your dry nitrous system. In addition to full control of your A/F curve The Interface can also retard timing when your nitrous system is active, so you can now run full timing NA and make max horsepower & torque and then safely and easily pull timing when your nitrous system is activated. Unlike some other timing controllers The Interface will show the timing being pulled when using a scan tool, so no more worrying if the timing is actually being pulled. The Interface can be easily installed into a pre-existing nitrous system, including systems using progressive controllers and includes a pre-made wire harness for a simplified installation.
basketball, breaks, controller, hsw, installation, interface, leg, louisville, ls3, manual, microedge, nitrous, orange, player, unit, wire
