Cadillac CTS-V - Stand-still burnout issues
View Full Version : Stand-still burnout issues
9t8z28
08-17-2012, 09:42 AM
I am going to sound like an idiot, but I assure you, I know what I am doing!
I tried to do a stand-still burnout in my V the other night. It wouldn't do it. I reved it up, let the clutch go and she started burning. As soon as I put my foot on the brake, the car would try to activate traction control. It almost stalled on me. I tried all 3 settings, T/C OFF, Perf. Mode and Stability OFF. Nothing worked. What am I doing wrong?
What mode do you do your stand-still burnout in with your FOOT ON THE BRAKE ?
Dmax/04V
08-17-2012, 09:46 AM
I need to check my tables but I'm wondering if there is a torque management table in the ECM that may be futzing with this. I might also be over complicating this.
Edit: I just looked at the torque management table and with this car I don't think it is an issue. I can't see anywhere that torque management is limited in a specific RPM range, which is what you have with a lot of automatic trannys. That said there may be another limiting table or calibration in place, I'm sure someone will chime in with an exact answer.
9t8z28
08-17-2012, 09:51 AM
So since I am modded, this may be causing the issue? IS this something my tuner was supposed to adjust?
va mike
08-17-2012, 11:02 AM
i have no issues doing them. i got a new set of tires last week and have done 2 2nd gear standing burnouts already to where the road disappeared.
9t8z28
08-17-2012, 11:16 AM
Can you tell me what mode you were in when u did the stand-still burnout with your foot on the brake??
va mike
08-17-2012, 12:08 PM
i only had TC off, nothing else.put it in 2nd n dumped it then stood on the brakes.
cammedv
08-17-2012, 12:16 PM
i would admajin you have a upgraded 9 inch rear or something.
i dont have the balls to dump the clutch in seccond to do a burnout. i would be to afraid of exploding the geartrec diff in these cars.
cammedv
08-17-2012, 12:17 PM
that is wierd, when ever i do a burnout i just hold the t/c button until it flashed stabilitract off.
9t8z28
08-17-2012, 12:37 PM
So you had the car set to STABILITY OFF and you did a burnout with your foot on the bread and your car was burning out standing still?
va mike
08-17-2012, 12:45 PM
lol stock 04 rear with 87k on it. 2nd gear really rolls smoke off the tires.
Bacon
08-17-2012, 12:50 PM
I havent had mine long enough to really abuse it like this, but i know in automatic vehicle GM has what they call "abuse mode" which is different than torque management. If it senses wheel slip in the back compared to the front, itll limit power. I turned it off in my truck and was able roll the tires off after. Maybe its on these too? I havent tried a standstill but I can roll the tires off through an intersection pretty good.
9t8z28
08-17-2012, 12:52 PM
Yes, I can do a rolling burnout as well from a stop. What did you turn off on your truck so it would burn?
1BADCTS
08-17-2012, 01:44 PM
Nope, I have no issues with everything turned off.
Dmax/04V
08-17-2012, 02:15 PM
These cars have an abuse management table, but looking at it I can't see any part of it that would cause this. The table in OEM form is based off of TPS and RPM, but from what I see (as a newb at tuning) I can't find anything that would affect a burnout.
cammedv
08-17-2012, 02:59 PM
yup easily, need almost no brake to keep the car sitting there, however i only do it once and awile, and always stay in first. then when i launch the car i just blow the tires off in seccond and third.
9t8z28
08-17-2012, 03:06 PM
Do you think ABS could affect it?
mrwill76
08-17-2012, 06:30 PM
Just buy a line lock, hit the switch and burn as long as you want.
9t8z28
08-17-2012, 07:13 PM
Thanks but that doesn't fix the issue. I dont like bandaids
RADEoN
08-18-2012, 08:24 AM
A line lock is in no way a bandage....
cammedv
08-18-2012, 11:26 AM
when i was out for a drive today i did some testing for ya.
i did 2 back to back burnouts.
first one i had just tc off, dumped the clutch in first, sat there for a few secconds then launched, once i started spinning the 2nd the stability cut the power.
seccond burnout, i had stability off, started out in first, sat there, powershifted into 2nd, and dragged it out around one hundered feet, no loos of power.
id def say you have a tune issuie(dunno if its possible) or maybe a abs sensor acting up, or maybe your emergency brake is sticking,
maybe shoot a video of your problem, might help
Bacon
08-18-2012, 11:58 AM
I hit the TC and held it until stability control was off, rev'd it up a little and let the clutch out slow to get to a roll (my diff saver) then dropped the clutch and started roll them off. Didnt have to hold the brake much, then i let off and played tokyo drift all through an intersection. I got one thumbs up, one dropped jaw, and one look of disapproval. I dont know if that counts as 2 for 3 or 1 for 3...whats a dropped jaw count as?
va mike
08-18-2012, 12:38 PM
i did that shit in ocean city at cruisin week. turned onto the highway with everything off and nailed it. went almost lock to lock twice then grabbed 2nd, went half lock to half lock then straightened out n smacked 3rd. people loved it.
va mike
08-18-2012, 12:41 PM
try dumping it from a stop in 2nd. i take it to about 6k n dump it then jump on the brakes real quick. the clouds that roll off are incredible. did a big 2nd gear burnout at work yesterday, owner had a shitfit.
shadyLS6
08-18-2012, 12:49 PM
I did one on my old set of tires right infront of the tire shop.. 4.5k drop and roasted them, if i slam on the brakes to had when transitioning it will bog but no T/C activation like you discribed
hahaha, stock dif!!, fukin awesome next time you do a burner you gotta make a vid:nod::nod:
va mike
08-18-2012, 01:09 PM
haha yup i beat the hell out of everything i own. i no lift shift the bitch on the daily too. ill deff get a vid next time. gonna try n hold off on them for a few weeks lol
plastus85
08-18-2012, 02:36 PM
I tried doing a stand still burn out on the street and it did the same thing,,, bogged the car down.. tried a few times and same thing... if i do a doughnut, and then hit the brakes, the car will let me do a still burnout... wierd.
also at the track in the water box it did a burnout just fine,
cammedv
08-18-2012, 02:44 PM
lol once i have a built rear end i will do burnouts like that, with my h/c package on the car i can do huge rolling smoke shows
fastassls1maro
08-18-2012, 02:56 PM
you might be experiencing a safety shut down feature programmed into a lot of newer cars that are drive by wire. When the computer see's throttle and brake input at the same time it limits power for safety reasons such as the infamous "toyota stuck throttle syndrome" lol. Sometimes you can trick it though by letting off the throttle with the brakes applied and then slowly get back into the throttle.
9t8z28
08-18-2012, 04:07 PM
I am trying to figure out what is going on that is causing an issue that no one else is having, so yes, a line lock would be a bandaid. Thanks for your input
9t8z28
08-18-2012, 04:12 PM
Thanks for doing some research! Ill see what I can dowhen i was out for a drive today i did some testing for ya.
EdmundGTP
08-19-2012, 12:39 AM
Jesus.. reading through this thread made me wanna go out to the garage and give my diff a positive reassuring pep talk and maybe a hug. Way too paranoid to attempt these shenanigans.
STAGEUP
08-19-2012, 08:01 PM
I've done about 150 standing burnouts since 2006 with no issues. What you're experiencing isn't normal.
dr.duct_mossburg
08-19-2012, 08:24 PM
At some point in this thread, Someone is going to lose a rear end... lol just saying.
Since no one has posted a video yet... This is by no means what the OP is trying to do but I mean a burn out thread without videos? c'mon!
http://www.youtube.com/watch?v=V63Q-v7-_PU
STAGEUP
08-19-2012, 08:34 PM
^^^ that isn't a stand-still burnout. Boo!!!
toomanytoyz
08-19-2012, 09:09 PM
Stand still burnout? Don't you mean "brake stand?" :confused:
Rookies. :rolleyes: :D
va mike
08-19-2012, 10:24 PM
ask ben about 1 of mine, he was in the car. did it in his neighborhood. the street disappeared.
ill do another n get it on film in a few weeks lol
this is the aftermath. dumped in 2nd n stood on brakes for about 8 seconds then rolled it out.
http://sphotos-b.xx.fbcdn.net/hphotos-ash3/581203_10100622303620507_1780274586_n.jpg
cammedv
08-20-2012, 06:31 AM
do you have any wheephop mods, ie axles, bushing ect, because there was a pile of wheel hop going on there, recipe for disatster
TheLostDriver
08-20-2012, 09:56 AM
That was definitely not a stand still burnout
9t8z28
08-20-2012, 10:21 AM
By no means am I a rookie. My tires dont last 5K miles. when I was younger (32 now) I was lucky if my tires lasted a couple of weeks. Sorry I am not up to date on the correct terminology. :judge:
9t8z28
08-20-2012, 10:28 AM
Haha, yes, you are probably right! And I'll take the blame! Nice vid! :burn:
lollygagger8
08-20-2012, 11:25 AM
I just turned off the T/C and dumped from 2nd @ 4k and hit the brakes. I had to stand on them to get it to stand still.
http://www.youtube.com/watch?v=mdeGfNkI2ko
I went until the cords were wrapped around the Control Arms.
TheLostDriver
08-20-2012, 03:57 PM
Haha nice. What mods you have done?
07CTS-V
08-20-2012, 05:16 PM
I broke a rear rotor on this one. I hold the brake and work the throttle with my right foot and clutch with my left until it starts spinning, then I brake with my left foot. All with stabilitrac off.
http://www.youtube.com/watch?v=L0B791EXu_s
rand49er
08-21-2012, 06:18 AM
... I went until the cords were wrapped around the Control Arms.:lol:
plastus85
08-25-2012, 08:36 PM
OP... Did you ever figure this out? If you do please share because I can't do a burnout on the street (had no problem at the track in the water box)
GT Motion
08-25-2012, 09:06 PM
So you guys dont have much worry with doing standing burnouts? I have been shopping for a V for the last month, all day today I have been reading up on the diff issues and its got me spooked, then I see this thread and ya'll dont give a f*** hahaha I dont know what to think right now!
plastus85
08-25-2012, 09:19 PM
as long as you dont have wheel hop,,, the diff should be fine
GT Motion
08-25-2012, 09:31 PM
I thought it was from the shock of dropping the clutch. If its from laying into it during wheelhop that makes me feel a little better because you can reduce or eliminate the wheel hop with axles and what not.
FuzzyLog1c
08-25-2012, 10:23 PM
Did it do one of these things?
http://www.youtube.com/watch?v=VoPBSQFWXHU
And this is just for the raw sex appeal of molten steel:
http://www.youtube.com/watch?v=y2Q4OpGCfME
cammedv
11-02-2012, 04:05 PM
every figure out your problem?
heres a vid from the testing i did for ya
http://www.youtube.com/watch?v=hEwQi4VeztE
wcryan
11-02-2012, 07:50 PM
^ what a nice guy to waste his tires on you...... haha
B4CU
12-26-2012, 12:29 AM
Well, I am a little less interested in purchasing this car now... Good burnout though haha.
GT Motion
12-26-2012, 04:09 AM
lmao I was gonna say the same thing!
cammedv
12-26-2012, 07:49 AM
ah i watse my tires every season, i put 3k on it each season and always kill a set of tires.
it also depends on how much my neighbours bitch at me for noise. the more they bitch, the more clutch dumps i do !!
roninsonic
12-26-2012, 07:50 AM
line lock and call it a day.
