General Maintenance & Repairs - turn signal very slow right does not blink
k_garretson23
08-17-2012, 10:17 AM
my turn signals are very slow, my right one does not blink anymore. It just stays on. What can cause this?
goldylocks
08-17-2012, 11:38 AM
if it only doesn't blink on one side check for a burn out bulb on that side that can cause it not to blink
cambirdracing
08-17-2012, 11:52 AM
Sometimes the flasher will do that. Blinks on one side and not the other.
ramairetransam
08-17-2012, 11:53 AM
bad battery, hows your voltage ?
k_garretson23
08-17-2012, 12:31 PM
voltage is fine. I just found out one of my break light is out so ill change that.
Armageddon
08-17-2012, 12:44 PM
Always check your bulbs and sockets first. If you're still having issues try this.
There are two flasher units under the kick panel. One is for the hazards and one for the turn indicators. Do all the lights flash correctly with the hazards on? If so, drop the kick panel and swap the hazard and indicator flashers. They're identical part #s. If your blinkers start working correctly again order a new flasher.
Indicator/Hazard Flasher - ACDELCO Part # 19209674
http://i1091.photobucket.com/albums/i397/Dougiewill/MOD02.jpg
