Cadillac CTS-V - I want to convert to E85
View Full Version : I want to convert to E85
cts-vls6
08-17-2012, 03:48 PM
I'm moving to Houston TX soon and was thiking about convert to E85 fuel
What do I all need to convert to E85?
What I need to do to the tune?
my V makes 508rwhp with the help of the procharger,71er injector,racetronix in tank fuel pump.What else do I need to make this happen?
Skidmarcx
08-17-2012, 05:13 PM
Which pump do you have? 255? You may need a larger pump. Injectors should be sufficient, but again I can't be certain. Beyond that fill the tank and tune it
cts-vls6
08-17-2012, 07:46 PM
255 on the fuel pump
Onefast V
08-17-2012, 08:31 PM
Were your injector above 90% DC at the 508rwhp? if so you will need bigger injectors.
vmapper
08-17-2012, 08:55 PM
Something doesnt make sense if your IDC was at 90% with 71lb injectors, at 500rwhp levels.
Depends how you are running your fuel rails, if you are using a FPR with a return on a boost referenced 1:1, you can maximize pump and injectors. Pumps flow more at a tad lower psi, but the injectors look smaller, its a balancing act.
If its the GSS351 pump, probably wont be enough.
For the tune, if everything is spot on every other table, it should be a simple adjustment of the Stoich AFR table for E85...
your new value will be 9.83305
And now you can add timing... so adjust your high octane table, and enjoy the added power.
nicksbeast0-xll
08-17-2012, 09:11 PM
you need to first get a bigger fuel pump. maybe a walbro 400 or so.
you will also need much bigger injectors than you may be running now because you will be consuming 30% or more e85 than you do gasoline.
but the gains are awesome in all vehicles that ive hard of lol. my friends evo gain 60whp or so from e85. and i read that its a 80whp gain on the new gt-r's. so i can only imagine what the gains are on a cts-v!
im actually planning on running e85 on my evo8 here in a couple of months!
nicksbeast0-xll
08-17-2012, 09:13 PM
oh yeah! because e85 is a high octane fuel you can get a bigger pully on you're ooprocharger and run more boost safely!
boost = power
and e85 is like 2.79 here lol its awesome
Skidmarcx
08-17-2012, 10:48 PM
E85 is definitely in my future as well, but I wanna do it right... Which most likely involves redoing the fuel system with FPR and return along with an appropriate pump or twin pump setup... There is a guy on CF that converted his Maggied LS using a single 255 and 72# injectors, but his pump must be hating life I don't see it happening safely... But I'm not an expert
vmapper
08-18-2012, 12:08 PM
oh yeah! because e85 is a high octane fuel you can get a bigger pulley on you're ooprocharger and run more boost safely!
boost = power
The biggest advantage is probably being able to add timing, not necessarily boost. I would NOT recommend SMALLER pulley (bigger would mean slower turning head unit = lower boost curve) (as smaller = more boost btw) if lets say, certain mechanical parts were not up for the task. Its dependent on many factors, inducing intercooler capabilities, blower mapping, internal parts and the OPS setup.
But E85 has less energy per mole hence why it takes a shit load more of it. Also means, less energy per amount of fuel, meaning, mileage is actually worse, way worse. So is it really cheaper? Probably not. But extra power is always nice
va mike
08-18-2012, 01:46 PM
put a bosch inline with that 255 or upgrade that 255 to a walbro 400.
vmapper
08-18-2012, 04:10 PM
Only if it was that easy.
What are the dimensions on a walbro 400? I know the one end is much fatter than a 255HP. That would mean, you are now doing some fancy modification to the pump basket, if its even possible.
Have you successfully installed a walbro 400 to a cts-v basket?
There are many threads as to which alternative pumps will work without too much headache, a walbro 400 is not one of them, not out of the question, but just not ideal IMO
255 Walbro OR pn. GSS351 or GSS352 are the same size as the stock pump.
vmapper
08-18-2012, 04:15 PM
You can also use A Denso 19513-1270 - BUT realize these draw DOUBLE the current.
You can also go with Kyosan 895091-0810 which is a modified Denso (toyota pn 23221-46110 equivalent) Also runs double the current - quiet and is larger so modification of the bucket is a MUST. also flows a hell of a lot 390lph @14V @ 43 psi. hotwire is a must.
Another alternative is a BAP.
1BADCTS
08-18-2012, 08:35 PM
I wish e85 were more readily available in my area... I would convert in a heartbeat!
NEED MO POWA!
08-19-2012, 12:40 PM
where in houston are you moving to? e85 is kind of hard to get around here.
Stone17
08-19-2012, 02:02 PM
Kroger sell it but it's still hard to find.
itsslow98
08-19-2012, 09:54 PM
Like said, bigger fuel pump no doubt but I think you might be able to get away with the injectors you have depending on just how much timing you add.
cts-vls6
08-20-2012, 07:27 AM
I will have to ck my injectors and reading all the post so far I know I will need bigger fuel pump,thanks for all the info guys.l be moving to the southwest side of Houston.I know some gas place have e85
gabe-v
08-22-2012, 10:11 AM
Let me make this disclaimer. I have no practical experience in this and I may be stating the obvious. If so please ignore me.
But just from a basic swap i.e. not for performance benefits just from being able to safely run E85. Aren't there o-rings (within the fuel system/lines) that are supposed to be replaced b/c E85 is more caustic than regular petro? Possibly the stock V already has these synthetic 0-rings/materials. Also for a previous project I was working on my research turned something up about having the tank coated, again to protect against the more caustic fuel, but this was for a 40 year old Datsun tank so maybe this is not an issue for the V ???
Stone17
08-22-2012, 12:30 PM
Check this place out.
VP C85 NEW (E85) 55 Gallon drum
Item Number: VP-C85
Price: $610.00
http://www.hyperfuels.com/
NeonRon
08-25-2012, 07:50 AM
Pretty much every gas station in the area of Metro Detroit where I live has E85. I didn't know it was a higher octane fuel. I used to use it on a Dakota flex fuel magnum V8 I had a while back. I never noticed a performance difference, only that the tank emptied sooner.
liqidvenom
08-25-2012, 03:16 PM
Its no different than if you ran 105 octane fuel, you have to adjust your timing tables to make use of the extra ability the fuel might allow you.
NeonRon
08-25-2012, 10:16 PM
Sounds like I should look into it. It's super easy to get around here and it's always twenty to thirty cents cheaper than the lowest octane gas the station sells. I paid 4.10 today for 93 octane and E85 was at 3.65.
Onefast V
08-26-2012, 12:23 AM
It burns 30% faster so unless its 30% cheaper you have to decide if the extra power is worth it
NeonRon
08-26-2012, 07:30 AM
It's not 30% cheaper, so unless the power increase is pretty noticeable, it doesn't seem to be worth the trouble. Can the crossover be done with tuning alone, or will parts need to be altered and replaced? Because I have a good friend that does my tuning for next to nothing but if I start adding his "real labor" to a project it becomes a different ball game.
Frostbite
10-28-2012, 09:37 PM
Today's gasoline has up to 10% ethanol in it already, so most modern fuel systems are capable of running E85.
