Gears & Axles - 8.5 10 bolt
View Full Version : 8.5 10 bolt
bBody22
08-17-2012, 06:47 PM
how do i get the C lookin deal out thats holding the spyder gears up in a 10 bolt rearend. i am trying to get to the c clips to take out my axles but i am having a hard time getting that deal out any help would be gladly appreciated
caturnbull1
08-17-2012, 06:50 PM
flip it around and there should be one little bolt in the middle after you take that out push your axle in and the c clips holding them in will fall out
caturnbull1
08-17-2012, 06:52 PM
well that was for my stock 10 bolt on the 99 camaro idk about the 8.5 10 bolt
bBody22
it has two springs in it "the C deal" at the top and the bottom is that what u are refering to
bBody22
08-17-2012, 06:53 PM
mine is in a 94 Caprice
caturnbull1
08-17-2012, 06:57 PM
oh ok well it must be diffrent. i didnt have any springs on the clip that held the axles from moving in. just more of a u clip i guess with one bolt on the closed side of the u took that out pushed the axles in and the c clips holding the axles fell out easy. the bigger 10 bolt must be diffrent sorry for the no help.
bBody22
08-17-2012, 07:52 PM
whats your number so i can send you a pic if you dont mind
caturnbull1
08-17-2012, 08:11 PM
cell?
1981TA
08-17-2012, 09:32 PM
If you look at the posi unit, do you have a thick bolt that's between the axle ends? If so, that bolt needs to be removed. There's a little bolt at one end of the thick bolt, which I think takes a 5/16 wrench to turn. Take the little bolt out, slide the big bolt out, push the axles inward, and the c-clips should fall out.
