Ignition problem
Ignition problem
alright changed the igintion control module because it went bad...then changed the spark plugs with what was in the car the ngk tr6 plugs....then took car for a ride it popped a code of 43 some ppl say knock sensor or esc..
which one is it or is there other problems
What PCM are you using??? F-body or B-body?? The F-body has 1 knock sensor!!! The B-body has 2!!! SO if your using a B-body in an F-body with only 1 knock sensor itll set your code!!! Im also pretty sure certain knock sensors are for certain years Maybe some others will add their input Also check the Knock Module inside the PCM if its gone itll set the same code!!! Hope this helps
