wide band question
wide band question
looking at getting a fast wb can I hook that into my back O2s or should I have a 2 new bungs put in I have an SLP predator tuner that has a tune in for rear O2 turned off Im thinking that would be the easiest if it doesnt cause any problems.I am old school had alot of fast cars but new to this tuning stuff want to do it mysellf as much as possible but also do it right any help would be greatly appreciated
i am also going to hook up a wideband,but i was under the impression that u want to put the o2 a few inches past where the left and right merge in the y pipe for the most accurate reading,but i could be wrong.
not trying to be rude but like I said earlier I have the stock exhaust and am not sure if I have the room dont dyno shops just stick the sensor in the rear during a tune if that is true why not behind the cats in the Y pipe
ok last question preferrably a tuner but any response welcome Im looking at doing a full exhaust during the wiinter am I understanding this right that after the cats the O2s would give a leaner mixture reading that being said if the afr read 13.1 it may be more like 12.7to 1 agree that this is not optimal is this possible to do some tuning until the exhaust is complete again I realize this is not the best but I would stay on the safe side by watching my E.Ts and staying safe by understanding the cats properly they do increase oxygen am I correct by thinking this way
As has been stated a few times previously....just weld in a bung before the cat, and tune the car. Do NOT log WB data after the cats.
I'm sure others will chime in here...but that's my thinking.
could a tuner please pm there phone # I uunderstand everthing everyone is saying but knowone is really answering my question and I am not good at this typing thing if I can talk to a engine builder or experienced tuner I could probably answer my questions in 5 minutes
Don't forget it should be angled down slightly so as not to hold condensation. Good luck with your mods.
Exactly. Not trying to sound harsh here, but this is a pretty straight-forward operation. Just weld the o2 bung "pre-cat"...anywhere from "9 o-clock to 3 o-clock" on a permanent installation (to avoid killing the o2 from condensation), and tune the car. It really is that simple, and should not be done any other way.
