Gears & Axles - TA Rear Performance Girdle
View Full Version : TA Rear Performance Girdle
DNTBJELOUS
08-18-2012, 12:50 PM
Just recently ordered one of these. Has anyone seen any differences in the way their rear ends react when launching? I know it helps with the deflection of the ring gear. Is this true or did I just fall for a gimmick haha
ULTIMATEORANGESS
08-18-2012, 01:55 PM
ive had two covers. i just a had an LPW installed a couple weeks ago. its supposed to be strong. it looks nice and holds a lot more oil than a stock cover. having a drain plug is also good.
no, i cant notice a difference.
goober35
08-20-2012, 10:49 PM
Helps launch NO
Helps to buy you some more time before you need a new rear end YES.
Nemesis350
08-20-2012, 11:27 PM
Helps launch NO
This sums it up lol
After rebuilding the last rear i destroyed (about 20 track passes) i spent the $$$ for the girdle and i'm going on 2 years and around 75 passes and the rear is holding up without an issue and still no noises. Sure i can't get below a 1.9 60ft to save my life but it's not from a lack of trying.
lt1 sport
08-22-2012, 11:33 PM
Ive set up a couple rear ends for m6 cars using the girdle cover, but i also put in a solid crush sleeve. They have been holding up well, the biggest thing i like is the fill and drain plugs.
jc98ss
08-22-2012, 11:48 PM
not to hijack, but in the product description for solid crush sleeves it says to make sure your installer is familiar with installation......what do you do different when setting a new ring/pinion with this part?.....i've been thinking about getting gears/girdle to hold me oven until i can buy a 9"
