Locked Converter on Dyno
I picked up 30hp doing that. I hear it wears out the convertor faster, but I'm not sure by how much. I've been locking it up in 3rd at the track for years with no problems.
Originally Posted by Mooobunnny
My cheap Midwest get locked on the dyno and at the topend of the track.
Chris
Chris
What does your rpm's drop to?
how exactly do you lock the verter in 3rd gear? And then have it unlock in OD as to not say blow the 3-4 on highway aggressive driving. any url's for setting this up?
i assume at a rpm point you lockup but you definitely dont want to shift to 4th locked up right?
I don't think that it's going to matter much whether the converter is locked or not when hitting the 3-4 shift at WOT.
WOT 3-4 shifts are clutch pack killers regardless, IMO.
the dyno tech uses a scan tool to override the computer and lock the converter....OR you can install youro own switch...
Originally Posted by gator's 99TA
locking the convertor on a nitrous run is pretty darn aggressive. make sure you have strong kevlar clutches in that unit!
Originally Posted by cyipher
who has a how to on installing a switch? or a least wiring diagram? And does it throw a ses light
i dont have one myself but from talking to people, im pretty sure it WILL throw an SES if you dont tune the code out.
