Fueling & Injection - Which pump & Inj. for 1000hp+ street
KY Nova
08-19-2012, 04:02 PM
Guys, I've been researching for weeks and talking to different companies and i'm still here with questions. I'm building a 402ci with a F1A that i'm told will be making 750rwhp or better. This is going to be a street car most of the time with occasional trips to the track to play. I'm getting a Ricks tank and thought about going with the Eliminator pump, but i read here that they don't last long on the street even with the PWM. So, i've been looking at Magnafuel. What pump would you recommend?
Secondly, i was told that the 80lb siemens would be good inj. for it. I've read here where a supporter used a formula for their inj. to size them to your combo and the 80's look tapped out for me. I'm running the E38 ecm. What injectors would you use?
This car will see frequent 35-75 mile trips one way.
I would appreciate any help or leads to someone who can help. I'm mixed on this, along with not very experienced in this area.
Thanks
Allen
LS1NOVA
08-19-2012, 04:09 PM
If you wanted to oversize your fuel system a tad the Magnafuel 4303 is a beast that will live on the street. They offer two other smaller "street" pump options in the same family of pumps. Magnafuel 9950? regulator is nice too. Id go FIC1000's on the injectors.
KY Nova
08-19-2012, 04:20 PM
Thanks for the info. I've seen alot about the FIC and ID injectors here, but i don't have any experience with either. Are the FIC's good for the street(idle and tuneability)?
I8UR4RD
08-19-2012, 05:28 PM
I personally do not think you will see a difference between the ID 2000's and FIC 2000's other than price, but I have not done the back to back testing, but either way people seem to go they always come out happy. Call Jon or Cole at FIC and they will take care of you. You can also call lonnies about a twin intank system. I am going with dual 340lph pumps intank and also running a built motor and f1-a.
KY Nova
08-19-2012, 05:34 PM
Thanks. This is in a 71 Nova. Do they or can they make an intank for it in a Ricks tank you think? What injectors do you run?
Lonnies Performance
08-19-2012, 08:54 PM
I have done some in-tank pump kits for various custom tanks.
If you have any specific dimensions, I can determine if a dual intank kit is possible.
I also offer complete line kits & injectors if interested in a turn-key solution.
Feel free to call if you want to discuss in more detail.
KY Nova
08-19-2012, 08:59 PM
I'll have to give you a call. Thanks
LS1NOVA
08-20-2012, 12:49 PM
I used a set of FIC2000's in an 06 GTO and they idle and perform very well.
KY Nova
08-20-2012, 07:43 PM
I'm going to have to call them and some others. Appreciate the input.
KY Nova
08-21-2012, 08:37 PM
Talked with vendors today and think i'm going with a Magnafuel 4303(750 Protuner) pump kit and ID1000s now. What do you guys think? After speaking with many today, this sounded like a great setup.
Thanks to those who gave input.
Allen
ZL1Killa
08-22-2012, 06:25 AM
does your setup involve boost? are you going to be running a fuel pressure regulator? did you check out FIC injectors?
KY Nova
08-22-2012, 09:15 AM
Yes, im running an F1A on a LS2. YES, THE regulator is theirs also. I checked with FIC "FUEL INJ.CONNECTION and FUEL INJECTION CLINIC". Do you know something that may be of help or interest?
Thanks for the input or questions
Allen
ZL1Killa
08-22-2012, 10:36 AM
no, just wanted you to check all vendors for pricing & data & information and compare them all
MIGHTYMOUSE
08-22-2012, 01:00 PM
if was my car i would run a external walbro 255 full time and kick on a external bosch 340 with boost or tps.
that will give you OEM dependability and keep the noise down along with more flow than you can shake a stick at.
KY Nova
08-22-2012, 02:10 PM
I'm really behind on this type of stuff, that's why im looking for opinions and or suggestions.
MIGHTY MOUSE, would you be willing to go over that setup briefly over the phone?
buick_lsx
08-23-2012, 04:10 PM
any links to a external 340?? ive been looking for external pumps bigger than the 255
MIGHTYMOUSE
08-23-2012, 04:14 PM
google bosch 044
i dunno how it got 340 designation its more like 300, a hoss as pressure goes up tho.
http://www.jayracing.com/images/Bosch_044_vs_Walbro_255HP.JPG
buick_lsx
08-23-2012, 04:19 PM
how much would dual 044's support over 255's....or just one 255, and one 044 like you described
ZL1Killa
08-23-2012, 09:04 PM
where are you located? We may be able to hook you up with vendors such as Lonnies, NastyN8, Racetronix, Heintz, FIC that can be of awesome assistance.
FIC offers injectors, the others offer injectors and fuel needs from complete external systems to internal systems. They (NastyN8 & Heintz & Lonnies) can all give you a quote for all wiring, braided fuel line & AN fittings and etc... all you would need.
check the fuel and injector sticky under this main section (yellow at top of forum) and you will see a lot of information for fuel pump size and max flow with a set of injectors. for instance:
stock 190 Lph pump, max 8 x 38# injectors
255 pump , max 8 x 50# injectors
350 pump, max 8 x 70# injectors
combination thereof, I have an internal 255 pump and an external 044 pump & setup from heintz (local to me & awesome guys) and I'm making close to 800HP
KY Nova
08-24-2012, 04:47 AM
I've read the pump sticky along with a ton of other stuff here and there. You know how it is trying to make that decision on something you don't know much about. I really appreciate everyones input and help. Kentucky
MIGHTYMOUSE
08-24-2012, 07:22 AM
if you still need a hand pm me a phone number
KY Nova
08-24-2012, 09:54 AM
Appreciate the offer. This is my first build of this type and caliber and you read good and bad about most things. This stuff isn't cheap as you know and I just want to make the best choice the first time.
konceptracin
08-24-2012, 09:59 AM
MM what injectors did you run in your ta?
MIGHTYMOUSE
08-24-2012, 10:49 AM
for the longest time i ran good old low z delphi 96# and right before i sold it i changed to FIC high z 120's that had just came out.
Twotonefreak
08-24-2012, 11:55 AM
Take MM's advice and run a 255 in-tank and a 340 or larger external pump.
Only other advice I can give is to over build it now so you don't have to worry about it later on down the road.
I did something similar in my 02 Z06. 255 in-tank. Sumped tank feeding a Magnafuel 4703. -10 feed and return. ID2000's with Edelbrock rails. My IDC on race gas is only 47% at 7,500rpm and making well over 1,000.
Bobsmyuncle
08-26-2012, 08:01 PM
look at the new holley dominator dual pump. the 12-1400 or 12-1800 designed for boost/nitrous, on pump runs all the time and the other for when u need it. all in one setup, and theyre dirt cheap, and whisper quiet and designed for street use unless 75% of the pumps put there. the 12-1400 says it will suport 975hp, i have the 12-1400 and an aero 340, at about 1100hp and fuel pressure aint droppin.
KY Nova
08-27-2012, 05:20 PM
I hadn't really gave them a thought, because you don't hear or see much about them. I'll check though. Thanks
Sarg
08-31-2012, 07:11 AM
What about an eliminator as a secondary pump, activated by boost and a 255 as a daily pump? Is there a concern about the eliminator (or other higher flowing pump) overwelming the smaller pump and backfeeding it?
