Large cube timing
Old 08-19-2012, 05:58 PM
nwalton29's Avatar
Default Large cube timing
Whats the max timing on a 445 CID w/ 245 ETP cath port heads with 12:1 compression. Running 93 octane?
Old 08-19-2012, 06:35 PM
BLK02WS6's Avatar
Gonna depend on the cam - and therefore the dynamic compression ratio... only the dyno can tell you...
Old 08-20-2012, 05:16 AM
nwalton29's Avatar
Would you think 27 deg is feasible in that large a motor?
Old 08-20-2012, 05:34 AM
BLK02WS6's Avatar
I think that is probably kinda high for that compression. I had 12:1 in my 408 with a big cam that lowered the DCR a good bit, and it made best power/torque at around 25 degrees... Don't think more cubes will make much difference on the timing. Like I said, you're gonna have to get it on a dyno to find out where it wants to be...
Old 08-20-2012, 12:03 PM
nwalton29's Avatar
Well it was dynoed, three pistons fried a little later. I'm thinking too much timing. I wont go back to that tuner.
Old 08-20-2012, 12:55 PM
BLK02WS6's Avatar
The rule of thumb is to always start low and work up - especially with something like that...
Old 08-20-2012, 01:03 PM
RAMPANT's Avatar
I was going to say 23-24 with that compression. We had 27 with my 455, but it was only at 11.1:1 and 94 octane.
My 412 was at 12.4:1 and would only take 23 degrees for best power on 94 octane. It also preferred an AFR of 12.4. My 455 likes 12.8.
Old 08-20-2012, 06:35 PM
BLK02WS6's Avatar
Same here - mine wanted 12.3-12.5 AFR...
Quick Reply: Large cube timing
