Pontiac GTO 2004-2006 - PSI for drag strip
joeyagls1
08-19-2012, 08:52 PM
I will be going to the strip next month on my new set up, right now I am running nittos nt05's drag radials, what is a good psi I should set them at for good grip?
Dyno Junkie
08-19-2012, 10:50 PM
Haven't used those myself, however with Mickey Thompson it took a bit of trial and error.
LS1 running 245/40/18 M/T's need to be dropped down to 15psi to get traction.
265/40/18's with same engine worked all the way up to 26psi.
Changed to LS3 and the ideal number is 21.5psi.
These are all with high stalled auto.
I'd start around 22psi and go from there. It usually takes me a few runs at each tire pressure to figure out where to put my baseline pressure. Then adjust according to track conditions for each time.
gconnoyer
08-20-2012, 08:31 AM
Start at 18 and work your way down.
How much power are you making
joeyagls1
08-20-2012, 01:31 PM
Yeah, I am getting hoosiers maybe, but for not got the nitto's
joeyagls1
08-20-2012, 01:32 PM
That seems like a good spot to start. I was def too high last time I was at 30.
470 at the crank.
joeyagls1
08-20-2012, 01:33 PM
Yeah the conditions are for sure I have to check for, hot cold sunny? you know, thanks man. I will be testing and tuning and then when I am about to race I should have the right PSI.
gconnoyer
08-20-2012, 02:32 PM
470 at the crank? Did you have your engine put together by a shop?
I'd say 17-18 will be the sweet spot
joeyagls1
08-22-2012, 09:10 AM
I done everything except the machining on the heads tb an intake.
Yeah everybod is saying around that area so will do man, thanks.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
