FS: 69 ProStreet Camaro Z28 | 389 SBC + TH400 | Street & Race Ready
Year: 1969
Make: Chevrolet
Model: Camaro
Price: $30000
Mileage: 106283
Private or Dealer Listing: Private Listing
Location (State): FL
Color: Red
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has other engine
-What is your First & Last name?: K.A. Wilson
-What is your email?: kawilson94t@gmail.com
-What is your City? : car is located in Melbourne
-What is your State? : Florida
-What is your Zipcode? : 32934
This is my ProStreet 69 Camaro Z28 clone with a small block Chevy 350 bored and stroked to a 389 with a built TH400. This is a complete, running, street or track car, unlike a lot of first gens where the motor is "almost done" or it is in pieces or covered in primer. I love this car, but it is time for me to move on to new projects.
- Converted to a Z28 in the late 80s
- The engine is a 350 bored and stroked 389 cid 700 hp w over 525f/p torque @ 3600 rpm on engine dyno
- Built by Kendrick Performance in San Antonio, TX. With receipts for over $14,000 on just the engine (I can send you the scanned receipts/invoices)
- Car has been driven less than 2000 miles since - but never raced
- The block is a Chevy 350 4 bolt main
- Scat Forged 4340 crank
- Eagle H-beam rods
- JE Forged flat top pistons - coated
- Dart Pro-1 CNC 227CC heads
- 2.08 1.65 Manley stainless swirl polished valves
- Comp Pacaloy springs
- Titanium retainers
- All ARP head bolts and ARP main studs
- Comp Solid Roller cam with 575 Lift 300/308 duration
- Jessel shaft rockers 1.5 ratio
- Comp hi-tech push rods
- Polished hurricane straight runner intake ported and flowed
- Barry Grant Race Demon R/S 825/1025 Carb
- Turbo 400 (TH400) transmission
- Trans brake, manual reverse valve body
- Extra transmission clutches built by Transmissions by Lonnie Well (Texas)
- Line lock
- MSD small cap billet distributor
- MSD Digital 6-Plus box
- MSD wires
- MSD Blaster HVC coil
- March Ultra serpentine belt system
- Polished heavy duty water pump
- Hooker 1 7/8 ceramic coated headers
- 3 1/2 50 Series Flowmaster mufflers
- K&N air filter
- Mini hi-torque starter
- Barry Grant 200 hr fuel pump and filter
- 8AN fuel supply and 10AN return
- Art Morrison 4-link rear clip with Ford 9” housing
- Poly bushing end links
- Alden Eagle adjustable coil over shocks
- Strange carrier with 35 spline axles
- Lenco Billet Locker
- Daytona pinion support
- 1350 series u-joints
- Moroso anti sway bar
- Motive 4.11 gears
- Wilwood Pro Street rear disc brakes with parking brake
- Front disc brakes with drilled rotors
- American Racing wheels 8x15 with BF Goodrich T/A P215/60 R15 93s tires
- Weld Racing Aluma-Star wheels 15x15 with Hoosier Pro Street Radials 29x18.5 tires
- 8-Point Roll Cage - painted and padded
- 5-Point G-Force harness
- Wizard polished radiator
- Electric fans
- Autometer Cobalt Blue tach with shift light
- Autometer gauges
- 15 Gallon trunk mounted fuel cell
- Optima battery
- Trunk mounted battery box
- Energy suspension front bushings
- New ball joints
- New idler/pitman arms
- Maxi-Cool Cooler with temp gauge
- Front lower spoiler
- Eclipse AM/FM/CD head unit with hide away EQ/DSP
- 2 Sets ads 5 2/10 Kicker Subs
- 1 ADS-6channel amp
- 1 4-channel amp, center speaker
Price: $30,000
Contact: kawilson94t@gmail.com
