General Maintenance & Repairs - Warning light with arrow pointing down to a small water line.
CaptMichaelJohn
08-20-2012, 03:13 PM
I did my research, it said low coolant. Just topped off my coolant and drove for 2 hours today, still on. The coolant is not leaking or anything either.
Could it be a sensor?
Could it be something else?
Please halp! :(
Daves99Formula
08-20-2012, 03:21 PM
i would say your sensor just needs to be cleaned.
blk/slvr02ss
08-20-2012, 03:22 PM
Just needs to be cleaned they always do that.
mike171562
08-20-2012, 03:23 PM
The coolant level sensor on these cars are known to go out, you can take it out and clean it, replace it, or just unplug it. Its on the radiator just under the fill cap
wssix99
08-21-2012, 05:46 AM
Did you check the level in the radiator or oveflow bottle?
CaptMichaelJohn
08-21-2012, 10:55 AM
Ahhh, okay thanks!
Yea I knew it must have been a sensor or something cuz i TOPPED THAT PUPPY off haha.
wssix99
08-21-2012, 05:01 PM
How did you top it off? It's possible to have a low condition at the sensor in the radiator with a topped off overflow bottle. You need to check the level under the rad cap to make sure it's the sensor.
DebbieInc
09-11-2012, 06:06 AM
I have the same problem, and have had it for a long time now. I've taken the sensor off and cleaned it very thoroughly, topped off radiator and overflow with the appropriate coolant, but yet that dumb light continues to come on.
wssix99
09-12-2012, 06:13 AM
If you do a search, you'll find that this rarely works. The sensor needs to be replaced.
