BadBirdie
08-20-2012, 03:51 PM
Well i did this fix once before where you add solder to the "T" on the body control module to fix the windows/radio randomly cutting out. It started doing it again so in the process of fixing it again i accidently let the line of solder i was using touch the BCM and i heard a pop(of course like a true dumbass i didnt disconnect the battery first). I put everything back in place and now i cant start the car. When i try i hear two quick clicks that soung like they're coming from around the fuse box in the engine bay.
The radio and windows will work until i try to start it. Horn works. The fuel pump primes. The power door locks/keyless entry remote doesnt work. also the door dinger doesnt work. The security light is not on or flashing at any point.
I've checked my fuses related to starting and ignition. Do i need to buy a new BCM? or it is something else? i dont know what else to check. If i try putting in my buddies BCM in from his 95 formula that would just be a waste of time right since its already programmed to his key?
Yes im stupid and i need help fixing this. Im so pissed off at myself right now. Please help me
