custom cam grind
Old 08-20-2012, 09:49 PM
slamminjim's Avatar
Default custom cam grind
Thinking about getting a custom cam ground.
Looking at doing a 238 242 .586 .602 110 lsa.
What lobes to have it ground on. Xer, lxl?
Car is not a dd. It's a stock head with bolt ons
3000 stall and 4:11s. Any opinions? Specs are
Old rpm5. Not much info on site about that
Cam. Thx
Old 08-21-2012, 05:13 AM
mark21742's Avatar
I ran a similar cam in ny 346...238/242 .595/.595 112lsa. If you go with the cam your looking st is jump up to a higher stall...I got the best performance from a 4,000 stall with this cam.
Old 08-21-2012, 08:01 AM
Turd Gen Guy
1nasty86's Avatar
With a 3k stall id look into a 224/228 xer cam... But if u got with a bigger converter rock the 238/242
Old 08-21-2012, 09:47 PM
slamminjim's Avatar
N e more opinions?
Old 08-21-2012, 10:03 PM
99Bluz28's Avatar
I'd go with either a higher stall converter or smaller cam.
Old 08-21-2012, 10:16 PM
slamminjim's Avatar
Why do I need a 4000+ stall for this cam?
Old 08-21-2012, 11:32 PM
99Bluz28's Avatar
I'd ask someone that's ran that cam, for the best insight.
https://ls1tech.com/forums/member.php?u=80467
Old 08-22-2012, 05:41 AM
PREDATOR-Z's Avatar
totally agree
Old 08-22-2012, 07:03 AM
mark21742's Avatar
Lol look at the 2nd post....I ran almost the same cam and told you what size stall worked the best with it
Old 08-22-2012, 07:41 AM
slamminjim's Avatar
I am simply asking why such a large stall is necessary. What would be the negative factors of running a small stall. Also wanting opinions of other people that's ran this cam and what lobes to have it ground on. Thx for the advice.
Old 08-22-2012, 09:28 AM
mark21742's Avatar
If you run too small of a stall it can really bog down in the rpms where the stall is starting to spin the tranny until your rpms get high enough into rpm range where the cam is making its power.....if you have ever ran older 2stroke 3/4 wheelers or dirt bikes you know the feeling....kind of really bogs down, then when it hits the higher rpms it comes on like a light switch....the higher stall let's you slip the motor right up to where the cam is making its power and you get no bog down.
Old 08-22-2012, 09:35 AM
slamminjim's Avatar
Thank you Mark.
Old 08-22-2012, 09:46 AM
mark21742's Avatar
No problem man, just trying to help.
