Dynamometer Results & Comparisons - MS3 with LS6 heads and intake results...
ELDIABLO
08-21-2012, 08:04 AM
Well I finally got a chance to get the SS tuned and dynoed. This was a quick little budget build I did in my garage and I'm proud of the results.
The car made 432hp and 395 Tq. This is on a M6 2000 ls1 (118k miles) with Pacesetter Lts, TSP ORY, Corsa, TSP lid w/ K&N, ported TB, LS6 intake, TSP MS3, and a set of stock LS6 heads. The car has a Moser 12 bolt with 4.10s, a huge Strange chromoly drive shaft, and stock (118k mile) clutch.
I took it to Bryan at Reckart Performance Tuning in Austin TX, and this guy knows his stuff. He got the A/F perfect, drivabilty is great, and he did it all in about 2 hours. He said my injectors are maxed out and could used a bigger maf. I also think we could have squeezed a couple more out if it if the clutch wasn't giving out, and the weather was a bit cooler. All in all I am really happy with these numbers considering it was through a 12 bolt with 4.10s.
I plan to go back soon once I get a set of injectors, bigger maf, a new clutch, and 150 shot of nitrous.
I will try to post a idle vid when I get a chance, it sounds amazing through Cosra.
Here is a pic of the Dyno sheet.
http://i94.photobucket.com/albums/l88/ws6toy/Untitled-2.jpg
reeperz28
08-21-2012, 12:27 PM
Awesome numbers through stock 243's! Just imagining with some tea ported 243's and a fast! Curious to why the power leveled off at 62-6300 rpm
ELDIABLO
08-21-2012, 07:48 PM
Thanks! My guess is because the intake is chocking it down.
I tried to upload a vid of the Idle but for some reason my camera is not up loading vids to my comp.
Nemesis350
08-21-2012, 08:35 PM
Awesome man! I think we'd make a good race with you still on motor ;) Although you're making about 25 more hp with the 243s
sportfisher410
08-21-2012, 08:36 PM
could you help me with something
ive got a 01 trans am ws6 with a vortech v-9 with 9 lbs on it ... whats the best heads and cam upgrade for cheap....
Sales1@Texas-speed
08-21-2012, 08:43 PM
Congrats on the numbers! Looks like a very solid setup!
sportfisher410
08-21-2012, 08:48 PM
1mean96ss
08-21-2012, 08:51 PM
almost the same number as my setup, congrats. ill be swapping to some PRC 227's and a ported FAST 92/92
FASTFATBOY
08-23-2012, 08:08 AM
LS6 heads(243 casting) and the 405 hp LS6 cam. Can get both for $500-$600
There is also a head with the same port as the LS6 but lowers the compression but I cant remember the casting number, with those you could up the boost.
ssdungeon
09-19-2012, 10:03 AM
I think they are the 317s that come on the Lq9s...
You could find a set of those puppies cheap on several forums....
