Pontiac GTO 2004-2006 - Rear vibration/hop on light acceleration.
silver86
08-21-2012, 08:42 AM
I noticed this first when at a light accel in second gear. Now its starting to do it in first gear. Is this a know problem? I feels like wheel hop but im not acceleration hard enough for that. If I accelerate aggressively its not nearly pronounced. 04 LS1 M6
svede1212
08-21-2012, 09:06 AM
Could be your limited slip. I'd try draining the diff and putting in some Torco and friction modifier.
Lil'Felt
08-21-2012, 01:43 PM
How hard is it to change the fluid?.
svede1212
08-21-2012, 05:59 PM
Easy. Just make sure you can get the "fill" plug out before you drain it. One easy way to refill is with a cheap hand transfer pump. Use Torco 90w140. Put in a little less than an ounce of Type "F" (as in Ford) friction modifier and take her out for a few hard slow turns and listen for popping sounds. If it does add a little more modifier and recheck.
silver86
08-21-2012, 06:06 PM
im thinking i broke something. Its pretty bad now. It feels like its mainly from the passenger side rear. its only at 10-20 mph but it feels like the wheel is going to bounce into the body.
409CISecondGen
08-21-2012, 07:25 PM
Could also be a wheel bearing.
svede1212
08-21-2012, 08:27 PM
Or a bushing or a bolt. Better get that checked out.
batboy
08-22-2012, 09:02 AM
The very first thing you should check are the half shaft bolts. This is a known problem with the 2004 GTO because the factory used inadequate locktite on the bolt threads. If those are are tight (12 bolts on each side), next check the to see if the CV joints are sloppy. Finally, check the driveshaft bolts and the carrier bearing.
silver86
08-22-2012, 04:12 PM
Thanks for the tips. Its still under warranty so I dropped it off at the dealer this morning. From my understanding the warranty company sucks but hopefully it's covered. Ill update when I hear something.
batboy
08-22-2012, 06:57 PM
You don't know how to jack up a car and check bolts? Holy cow! Why even post this thread?
409CISecondGen
08-22-2012, 08:06 PM
Why bother when he can have the dealer do everything for free?
batboy
08-22-2012, 08:43 PM
Seriously, so you would drive to a dealership when it's possible something could be wrong and take the chance of making it worse just to let some clueless tech look at it? Both of you guys, turn in your man cards.
gconnoyer
08-22-2012, 09:31 PM
He asked if it was hard to drain the fluid in the rear.....you guys are expecting him to jack up the car, find "halfshafts or axles", "CV joints", and driveshaft bolts and "carrier bearing"
-___-
In all seriousness, I'm glad you took it to the dealership. If you have NO inkling of how to work on a car, you're better off having someone that is supposed to know what they're doing fix it.
batboy
08-22-2012, 09:44 PM
:jest: I reckon you have a point there. :jest:
GTOSE
08-22-2012, 10:39 PM
Lol, if it's under warranty then I wouldn't even touch it.
Work smart, not hard.
batboy
08-23-2012, 06:39 AM
Way back when mine was under warranty, the battery cable loosened up and the car would not start. I suppose by your thinking I should have towed it to the dealership and let them tighten the cable terminal? Instead, I did it myself and was not inconvenienced with the car sitting in the shop all day and.or while the techs took turns driving the piss out of it.
exodus_gs1
08-23-2012, 09:55 AM
I completely agree with Doug your own work you have to learn somewhere. But the guy asking about the difficulty of changing fluids was a different guy.
GTOSE
08-23-2012, 01:33 PM
I'm pretty sure I was talking about OP's situation.
But by your logic, you should have a guy who has no tools or experience crawl under a car and see if he can make sense of it. Rather than taking it to a dealership, and if they fuck up, it comes out of the technicians pay as well as it getting re done correctly.
If I did have a warranty on any of my cars, I'd soak up as much of that as I possibly could, I hate wrenching on cars.
silver86
08-23-2012, 07:00 PM
lol The dealer said its the drive-shaft and are trying to find a replacement. As far as working on my own cars lol. Ive built my 86 mustang from stock to H/C/I and a Vortech S-Trim and tuned it myself. I think I know my way around cars. Since it was under warranty I just took it in. I was looking for incite or if this was a known problem, no more, no less. They said they are having a hard time finding a replacement and said they might just have a 1 piece shaft put in it if the warranty company will cover it.
silver86
08-23-2012, 07:03 PM
-___-
I didnt ask how to change the fluid, that was another poster...
silver86
08-23-2012, 07:04 PM
You assume I don't now you're making yourself look like an ass.
exodus_gs1
08-23-2012, 08:40 PM
Sooo what was wrong with your driveshaft? My buddy is kinda having the same problem. I will be over there tom to get a hands on feel but from what he explained sounds alot like this. Were they bent? Just un balanced?
silver86
08-24-2012, 09:07 AM
The center bearing is shot and they are having a hard time locating one.
exodus_gs1
08-24-2012, 09:42 AM
O damn, ok cool thanks. Hopefully they spring for a solid one and make your life easier
batboy
08-24-2012, 12:18 PM
The carrier bearing, that's the center bearing thing you are referring to (which is one of the things I told you to check), is not replaceable. You have to change out the whole driveshaft. The stock driveshaft is a piece of crap. I replaced mine with a high performance one from Gforce1320.
Posting a question on a car enthusiast do-it-yourself forum and then ignoring what was said to just take the car to the stealership seems a bit asinine to me.
silver86
08-24-2012, 12:56 PM
it's not that I don't appreciate the advice but if I can just drop it off and have it fixed for free why would I waste my time. I have better things to do with my time than work on a car that can be fixed free of charge. i just bought the car so I wasn't sure if this was a known issue. I will talk to then about a ds from gforce1320 and see.what they say,.thanks for the site!
