ad53030
08-21-2012, 06:35 PM
Well to my credit I've had it since 1997, just never really been able to do what i want with it. Still really can't afford to, but I'm going to anyway. Life is too short.
I know many of you guys have some beautiful and incredible performing cars, and likely will not care about my ugly duckling but here goes. Got it when I was 17, it was a 230 cu in 6 cyl and 3 spd on the column car. That first year i had it I swapped in a basically stock 350 short block with almost full race ported 462 fuelie heads, comp extreme energy cam, performer rpm, Holley 650 DP, HEI, and 1 3/4" Hooker Super Comps, BorgWarner Super T10 with a Lakewood Steel Scattershield, Hays clutch, and a 3.55 geared GM 12 bolt from a Nova. Engine bay looks like an 18 yr old did it but at least I used decent parts. Basically stock interior with 4th Gen T/A seats. Ran a whopping 13.7 on radial T/As with no traction in '98. So here it is unchanged or modded since then. I know it's sad. It's more sad to know how long i've been planning an LS swap but have had no $. Years ago I bought an LS T56 and a McLeod adapter with plans of swapping it behind the Gen 1 350 but it never happened.
So new plan is a super tight budgeted Cammed LS2/T56 swap. I plan to buy a complete pullout and sell what i have to recover some of my costs. I want it running and driving ASAP and I will mod from there. Read countless threads on LS1tech and will be doing my own harness with pinouts from here (super tight budget). Plan to cut and mod stock subframe to allow for stock oil pan, and a/c compression location using stock accessories.
One big question i have is wheels and tires. It has Rallies and BFGs on it now. I want 18s but have no time or $ to mini tub. What's the biggest tire I can fit in the rear of this thing? Thinking 275/35/18 with trimmed lip. Sound realistic? What about fronts. I do not want rubbing anywhere but want a decent tire under it.
Also, I see guys running the Dynatech headers and i know they are cheap and fit well. Are 1 7/8" primaries going to kill torque on a 364 cu in motor with stock heads? They are considerably cheaper than Doug Thorleys of Hooker Super Comps but I don't want to kill torque. Plan on using a set of Cal-Tracs to plant the tires.
This is set to start in about 1.5-2 months and I'm looking to be driving it about a month after that. Starting to collect parts now. Guess I will be buying my motor/trans from Ebay. Anyone have any great hook-ups on pullouts? Suggestions are welcome. Thanks for any and all help.
