Generation IV Internal Engine - trick flow ls2 220 rockers????
View Full Version : trick flow ls2 220 rockers????
1bd63nova
08-21-2012, 11:39 PM
i have a set of trick flow ls2 220 heads and i need rockers what are you guys running? which ones will bolt right on? any help would be great thanks
427 zeo6
08-22-2012, 05:12 PM
I've got a set of Jesels with some VC spacers. $480 and their yours. I went to ls3 setup, they won't work for me.
06X6spdGTO
08-22-2012, 06:29 PM
Im running stock LS2 rockers with a comp trunion upgrade unmilled 7.500 pushrods, Vindicator cam, and TEA Dual golds (NOW BTR Springs)
1bd63nova
08-22-2012, 08:00 PM
so how did you use the stock rockers the pedstal they mount to wont sit flat did you grid the lip off the pedistal for rockers?
06X6spdGTO
08-22-2012, 08:27 PM
Yep, Grind the lip down...
Call TEA and they can walk ya through it.
batboy
08-22-2012, 08:47 PM
There is a kit available if you don't feel like modding them yourself.
http://www.thunderracing.com/shop-by/category/Cylinder-Heads-and-Valvetrain/Cylinder-Heads/Total-Engine-Airflow-Trick-Flow-Cylinder-Heads_882.html
1bd63nova
08-22-2012, 09:07 PM
thats what i thought ill mill the lip off so the plate sits flush in the area and do the comp bearing up grade.. any one have pics of this?
06X6spdGTO
08-22-2012, 10:25 PM
what pics are you looking for??? The lifter tray ground down?? Or the comp Trunion rockers installed??
SILVERBIRD97
08-23-2012, 11:25 AM
You'll need to shim the base for proper rocker wipe and lifter pre-load.
06X6spdGTO
08-23-2012, 06:02 PM
Contact Mike@TEA
