General Maintenance & Repairs - coolant and turn signal issues....
stevez2885
08-22-2012, 10:02 AM
Ok first I just got back from afghanistan and my wife told me my car was leaking. I check underneath and sure enough there was coolant all along the oil pan and everything was wet. I couldnt see anything leaking so I wiped everything down and sprayed everything with brake clean. Drove the car and noticed the low coolant light came on so I drove it home and didnt see anything leaking anywhere. This morning I checked the coolant levels in the resevoir and the radiator and their both good. The car will not overheat and the t stat and fans seem to be working fine. I checked the oil and coolant and it doesnt seem that either are mixing. Any ideas on what this could be or where to check?
Also, my left turn signal isnt working in the front or back and the indicator on the dash goes bright,dim then off and is very slow when doing so when the right side on the dash and at the bulbs works completely fine. Any ideas? Thanks in advance guys.
stevez2885
08-22-2012, 02:31 PM
52 views and no ideas? :bang:
wssix99
08-22-2012, 03:44 PM
Check the weep hole on the water pump. If it starts leaking, (its behind the pulley.) it will be hard to see but the fluid will drip down to the bottom of the engine and on the A/C compressor.
Sounds just like a bad flasher.
stevez2885
08-22-2012, 08:15 PM
Hey thanks man, I was looking for it to come out of the weephole but found nothing. I figured it would be a flasher except the fact that the dash light goes dim and then goes off and neither light illuminates. But ill def check both
CATDIESEL
08-23-2012, 04:23 PM
collant leak on the oil pan is either the water pump or the waterpump gaskets. turn on the hazard switch and see if everything works correctly . If so you have narrowed it down to the turn signal switch. if the right turn signal works fine now then i would say the flasher is not the issue.
stevez2885
08-26-2012, 05:35 PM
Your right it wasnt the flasher....the rear turn signal bulb on the left side was corroded and I cleaned it and the fron bulb was shattered thanks to my bulb socket in the front needing replaced but I replaced the bulb in the front and the left side works fine now. As far as the leak I still cant find the coolant leak but I did notice my oil pan gasket was leaking and ordered one.....but FML its going to be alot more work than i though lmao
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
