Gen 5 Camaro External Bolt-On Tech - Granatelli turbo kit 550 wrhp to 1200 wrhp
granatelli sales
08-22-2012, 12:29 PM
A detailed break-down of the 2010-2011 Camaro Twin-Turbo kit and its components are as follows:
2 x PTE6265 Turbochargers with 4” Inlet Compressor ducting – Each capable of 65 lbs/min
Turbos are V band mounted on inlet and outlet to insure easy rotation, solid mounting and best of all there are no nuts and bolts entering or exit turbo body
2 x PTE 46mm Waste Gates Insure Maximum Control Over the Monster Turbos. Waste Gates Include Adjustable Springs to go from 4.5psi to 15psi (We factory set them at 7lbs)
All stainless steel and Heat temperature coated exhaust system components ensure a lifetime of reliability
1 x 50mm Tial Blow Off Valve
3 x Largest Front Mount Intercooler are Hi flow Bell cores with 3.5” inlets from turbos and a single 4” discharge pipe feeds direct to the throttle body. Intercooler Tanks are Black Powder Coated to Extract Heat Yet Fins Remain Untouched
Fiberglass Reinforced Silicone hose couplers ensure durability for year to come – no expense was spared
All the necessary Vacuum ports required to assist in installing the boost controller
1 x Oil Scavenge Pump & Brkt
Thermal Heat shielding for all effected lines
GMS Oil Feed & Return Line Kit are all precision clamped and crimped to ensure leak free connections
GMS/TTi 3.5” 6061 Aluminum Intercooler Tubing for lighter weight and better heat dispersion
GMS/TTi 4” 6061 Aluminum Charge-pipe
GMs/TTi 4” Aluminum Intake Tubing w/K&N Filters and K&N “Hydro Shields” for extended dust/dirt/water protection
GMS/TTi Aluminum Lower frame cover to ensure debris free road travel
The only TT kit that does not hang below the frame rail, ensure plenty of ground clearance
AEM Windshield Washer Bottle & Accessories
Polished Oil Cap w/oil return
Retains Factory Engine Cover
We offer many options from short blocks and long blocks to various turbo size upgrades and color choices. Factory Silver Powder Coated Tubing – Special Colors Available on Request.
http://www.youtube.com/watch?v=ceFNR4JG66c&feature=player_embedded
Video was from 2010 our kit makes well over the power that power now
http://www.youtube.com/watch?v=y2DATNvu5eQ
1200hp Camaro engine
granatelli sales
08-24-2012, 11:14 AM
New Video Coming Soon
granatelli sales
08-27-2012, 10:53 AM
Just Dyno a Camaro with our TT system made 650 hp on 8psi
granatelli sales
08-29-2012, 11:52 AM
NEW VIDEO
http://www.youtube.com/watch?v=IJrCOJvy4T4
granatelli sales
08-31-2012, 11:27 AM
Any questions
Turbo2L
09-01-2012, 03:13 PM
Any questions
What's the going rate for one of these and do you offer them with a 6266 or 6466?
granatelli sales
09-05-2012, 12:55 PM
PM sent
granatelli sales
09-21-2012, 01:46 PM
Call 805-486-6644 FOR MORE INFORMATION
granatelli sales
10-12-2012, 11:55 AM
we're very proud of the car; it's not only fast and pretty...
http://sphotos-b.xx.fbcdn.net/hphotos-snc6/285078_494042560626205_54606356_n.jpg
but it also wins! congrats to our customer (guy martin)!:thumb:
Blackpanther99
12-14-2012, 04:45 PM
I seen your TT build video, you guys do great work!
granatelli sales
12-18-2012, 02:20 PM
Thanks
granatelli sales
01-07-2013, 06:32 PM
Sale on all twin turbo kits pm for prices or for faster response call (805)486-6644
granatelli sales
01-10-2013, 02:26 PM
We're bringing back our Annual DYNO DAY on MARCH 9, 2013
For 3 pulls on Dyno day will cost
$55 Pre register
$65 Day of Dyno Day
YOU WILL NEED TO CALL IN AND REGISTER YOUR CAR TO MAKE THE DYNO PULLS
We do not know the classes yet but we're thinking
4, 6, 8 CYL class
CHEVY VS DODGE VS FORD
TURBO VS NITROUS VS BLOWER
LIMITED AMOUNT OF SPACE SO CALL IN FAST (805) 486-6644
PM ME FOR PRE-ORDER so i can send you a Registration form
98sickspeedblkta
01-26-2013, 07:08 AM
Sounds bad ass
granatelli sales
01-28-2013, 03:12 PM
http://www.youtube.com/watch?v=kQZ1PPAoWi8
It sounds even better with the Granatelli cat back exhaust
granatelli sales
07-09-2013, 05:03 PM
Granatelli Motor Sports - Gen5 Camaro Axleback Comparison - YouTube
Hear the sound of the turbos coming out the great Granatelli Axle back system
