Stock 862s or stock 241s on turbo 5.3
Old 08-22-2012, 02:57 PM
Jose93z28's Avatar
Default Stock 862s or stock 241s on turbo 5.3
So i been reading a few threads on this, but i would like a few more opinions, hopefully from someone running this setup, i got a stock 5.3 that im gonna turbo and i would like to know if there's any advantage from running the 241 heads over the 862? I know the intake valves are bigger on the 241s and they will lower compression a bit, but im trying to figure out what will be better for my build, im planning on running stock bottom end ls6 cam, and about 15 psi, also its gonna be in a 6spd car
Old 08-22-2012, 03:08 PM
NemeSS's Avatar
Keep the stock 862. Get studs and ls9 gaskets. Nothing wrong with stock heads if there's no damage. Stock compression is 9.4:1. The ls9 gaskets will slightly lower even more. Also may want to think about milling the heads just slightly to get a true flat surface. .003-.005 usually is enough
Old 08-22-2012, 03:22 PM
Jose93z28's Avatar
Forgot to mension i got a set of used 241s laying around, nothing wrong with the 862s just a broken bolt on the exhaust side but im pretty sure i can get it out.
Old 08-22-2012, 03:31 PM
NemeSS's Avatar
Smoke em if u got em
241 gonna put u around 9:1
Old 08-22-2012, 03:34 PM
Jose93z28's Avatar
So 241s better than 862s? And Just make sure theyre flat as well?
Quick Reply: Stock 862s or stock 241s on turbo 5.3
